Author Topic: Corel Buys Out Corel  (Read 1275 times)
Re: Corel Buys Out Corel
« Reply #1 on: November 27, 2009, 08:35 »
I'd be sad to see them fail, I cut my teeth on Corel products.
« Reply #2 on: November 27, 2009, 10:07 »
I can't remember why, but I didn't like the later versions of Paint Shop Pro, especially after they removed Animation Shop, and made you buy it separately.
« Reply #3 on: November 27, 2009, 10:08 »
Bloat?
« Reply #4 on: November 27, 2009, 10:11 »
Probably.
« Reply #5 on: November 27, 2009, 10:15 »
Yes, I was heavily into Corel software too, particularly on my early machines.
« Reply #6 on: November 27, 2009, 10:19 »
I'm only just retiring WordPerfect, Clive, as it doesn't like my latest printer. I still think it's a better WP than word, though.
« Reply #7 on: November 27, 2009, 12:06 »
PSP was originally a JASC product.  Corel bought them out a couple of years ago.
I must say, I do like CorelDraw.  The full version is very expensive but I got a 'lite' version with my graphics tablet and I love it for designing scroll saw patterns.  Inkscape is good but it doesn't compare to CorelDraw (and it keeps crashing on Vista machines).  I hope Corel survives.
« Reply #8 on: November 27, 2009, 12:20 »
Corel acquired most of their products, Gill, I think only Draw! was an original. I paid about £500 for it in the late 80s, but it was a tax deductible tool for me, and I earned a lot of money with it.
« Reply #9 on: November 27, 2009, 12:28 »
I used to use the DOS version of WP on my old 286 machine at work.  An improvement on my AT for certain!  The database was DBase 4 and the spreadsheet was Lotus 123 (all DOS naturally).  The first Windows OS I had at work was NT on a 486.
« Reply #10 on: November 27, 2009, 12:32 »
I had Windows 1, run time, on a 386SX (it might even have just been on a 286). :)
« Reply #11 on: November 27, 2009, 12:38 »
I had 3.1 on my 386SX at home.  Always miles ahead of what I was given at work.  But I downgraded to 3.0 for a while because I was using a version of Pagemaker for 3.0 and compatibility was an issue even back then!  My own favourite was Ami Pro 3.
« Reply #12 on: November 27, 2009, 12:47 »
One of many that seemed to fall by the wayside, XyWrite and WordStar for example.
« Reply #13 on: November 27, 2009, 19:16 »
Never heard of XyWrite but I used Wordstar 2000 for a while.  I was always looking for the perfect WP and I found it with Ami Pro!  I managed to keep it through Win 95 and 98 but XP finished it off.  :bawl:
« Reply #14 on: November 27, 2009, 19:17 »
XyWrite was favoured by technical writers as it could handle formulae etc very well.
