July 05, 2024, 10:48
Technical Help & Discussion
General Tech Discussion, News & Q&A
Router question
Topic: Router question (Read 2824 times)
David
Loyal Member
http://Wormdive_2
Router question
November 30, 2009, 00:33 »
I have just changed over routers,reinstated my old one for use of wireless network at home...I thought it would need reconfiguration but everything is fine !!! is this right surely not
Last Edit: November 30, 2009, 00:36 by David
Sandra
Ultimate Member
Re: Rouet question
November 30, 2009, 00:35 »
If you hadnt reset it from last time you used it and you are with the same ISP then it would still have the settings in David.
The only difference would be the wireless key, if they both had wi fi
David
Loyal Member
http://Wormdive_2
Re: Rouet question
Thats just it Sandra...I am not with the same isp !!
Sandra
Ultimate Member
Re: Router question
November 30, 2009, 00:38 »
Lots of ISPs dont need a username and password now, as long as the PPPoA or PPPoE is set correctly and the 0,38 is in place they seem to be able to connect as the line is a dedicated one to your phone number I presume.
David
Loyal Member
http://Wormdive_2
Re: Router question
November 30, 2009, 00:41 »
I have just checked my log on my isp and I am no longer online !!! this is very odd
Re: Router question
November 30, 2009, 00:43 »
Who does the router say you are logged into, David? Did you not use it at all when AA were fault finding?
David
Loyal Member
http://Wormdive_2
Re: Router question
November 30, 2009, 00:44 »
No according to the log I am not online now and no connection being logged for 42 minutes
Re: Router question
November 30, 2009, 00:48 »
Are you sure you've disconnected the other router?
David
Loyal Member
http://Wormdive_2
Re: Router question
November 30, 2009, 00:49 »
Yes its on the table...turned off I know these 2 wires are good but bl;;dy hell
I have done some speed tests and noted my isp comes up as IDNet ?
Last Edit: November 30, 2009, 01:00 by David
Re: Router question
Reply #9 on:
November 30, 2009, 00:52 »
I'll have to leave you in Sandra's capable hands, as I have to be up in the morning.
Night, David.
David
Loyal Member
http://Wormdive_2
Re: Router question
Reply #10 on:
November 30, 2009, 00:53 »
Night Simon...for once its not a problem
Re: Router question
Reply #11 on:
November 30, 2009, 08:03 »
It's very weird though, David. Any more developments?
David
Loyal Member
http://Wormdive_2
Re: Router question
Reply #12 on:
November 30, 2009, 08:44 »
Morning Simon...No its all working OK ...have not checked my log yet ...Have to do the school run
Re: Router question
Reply #13 on:
November 30, 2009, 10:21 »
As explained on Netters, David, BT have failed to cancel your connection to IDNet.
David
Loyal Member
http://Wormdive_2
Re: Router question
Reply #14 on:
November 30, 2009, 10:25 »
I got worried last night and posted in both....still I dont know if its a good or bad thing...I expect I will suddenly get disconnected later
Router question
