Hi guys,
Its been a long time since I have had to call on the wisdom of these wise walls, so here I go....
Basically I have installed a QNAP Nas on my network, it is of course always on and I can see it on my laptop running windows 7. I have easily mapped drives from my machine so that I can easily access them via the laptop.
Now the problem starts when I try to do the same on my GF's laptop. It is a HP laptop running windows 7 also. It came up once in the my computer section and I mapped it under my credentials, but then I deleted them again to reconnect them under hers. Now I cant see it and every time I try to connect using the path name it just says it is not correct.
any ideas?
thanks in advance
