Author Topic: CERN cuts power to part of the LHC, says the setback is minor  (Read 1057 times)
Just two days after the Large Hadron Collider (LHC) reached a major milestone by producing 1.18 TeV (more than one trillion electron volts) of energy, the particle physics lab CERN had to cut power to one of the accelerator's sites following a problem with a power supplier. The outage did not affect the cryogenics required for operation, and a CERN spokeswoman in Geneva, Switzerland, was optimistic that the power would be back up by 6:30 p.m. local time.
http://www.scientificamerican.com/blog/post.cfm?id=cern-cuts-power-to-part-of-the-lhc-2009-12-02
Re: CERN cuts power to part of the LHC, says the setback is minor
« Reply #1 on: December 05, 2009, 21:43 »
That's it - it's busted!  ;D
« Reply #2 on: December 05, 2009, 23:07 »
I told you not to fiddle around with the forum software!!
« Reply #3 on: December 05, 2009, 23:26 »
« Reply #4 on: December 06, 2009, 13:17 »
