Author Topic: Hauppauge WinTV USB Stick Aerial  (Read 3847 times)
« on: December 22, 2009, 00:50 »
My hubby has a Hauppauge WinTV USB Stick for his laptop but never uses it because the aerial is so poor.  It just doesn't pick up any broadcasts.  Is there any easy way to address this problem?
Re: Hauppauge WinTV USB Stick Aerial
« Reply #1 on: December 22, 2009, 00:56 »
You definatley need a proper aerial Gill, the ones they supply with TV cards and even the indoor type are fairly useless unless you are in an area with a really good signal.
One alternative he could try is Zattoo from :
http://zattoo.com/
Its a free program and covers most of the freeview channels plus a few extras. It runs a short ads when you change channels but seems to work quite well.
« Reply #2 on: December 22, 2009, 01:03 »
Thanks for the suggestion, Sandra.  I can't see him trusting zattoo, though.  I can't even get him to download programmes with Get_iPlayer  ::) .
« Reply #3 on: January 12, 2010, 02:13 »
I've now got a machine running in the UK... oh the fun of being able to watch proper telly (well a couple of shows a week that is).
