Author Topic: Connect two iPods to one computer - HOW?!!  (Read 4907 times)
« on: December 29, 2009, 22:56 »
This isn't for me directly, but two sets of friends have got multiple iPods for Christmas, and are struggling to connect the two iPods to one computer, so that each syncs separately with it's own library on the PC, and indeed, with iTunes.  Can anyone provide an idiot proof guide on how to do this?
Re: Connect two iPods to one computer - HOW?!!
« Reply #1 on: December 30, 2009, 09:42 »
Just connect them and sync, in my experience, Simon. I have three iPods syncing off this machine, it recognises each one and uses the appropriate play lists.
« Reply #2 on: December 30, 2009, 09:57 »
it could cause issues if they didn't set the names of the devices separately but that shouldn't be a problem. Are they using iTunes on windows?
Here is apple's guide to it: http://support.apple.com/kb/HT1495
« Reply #3 on: December 30, 2009, 14:34 »
OK, Playlists may be the key.  They are trying to sync with different Libraries.
Yes, iTunes on Windows, Sam, and they have different accounts, with differently named iPods.  I've passed that link on, thanks.
« Reply #4 on: December 30, 2009, 15:21 »
How have they created different libraries, Simon?
« Reply #5 on: December 30, 2009, 16:17 »
Yes.
« Reply #6 on: December 30, 2009, 16:18 »
I feel so much clearer now. :)
« Reply #7 on: December 30, 2009, 16:20 »
OK, yes, they have.  ;D
« Reply #8 on: December 30, 2009, 16:55 »
But how?
« Reply #9 on: December 30, 2009, 17:20 »
Two folders in My Documents > My Music, I think.
« Reply #10 on: December 30, 2009, 17:26 »
I'm not sure how they managed that. The simplest way forward would be to create two accounts and to move the respective libraries to the matching account.
« Reply #11 on: December 30, 2009, 17:34 »
Yes, I think I'll suggest that.
« Reply #12 on: December 30, 2009, 17:49 »
It's safe. ;)
« Reply #13 on: December 30, 2009, 18:03 »
You don't know them!  ::)
« Reply #14 on: December 30, 2009, 18:14 »
True. Mind if I keep it that way? ;)
