November 28, 2024, 00:32
Technical Help & Discussion
General Tech Discussion, News & Q&A
Rice Resurrects Even the Most Soaked of Gadgets
Topic: Rice Resurrects Even the Most Soaked of Gadgets (Read 1864 times)
January 01, 2010, 20:27 »
http://lifehacker.com/5435480/testimonial-rice-resurrects-even-the-most-soaked-of-gadgets
Re: Rice Resurrects Even the Most Soaked of Gadgets
January 01, 2010, 21:31 »
That's worth remembering, Clive.
January 02, 2010, 10:29 »
I'll start carrying a bag of rice around with me.
January 02, 2010, 11:29 »
Well, they say you have more little accidents as you get older.
January 02, 2010, 11:31 »
or should that be
January 02, 2010, 11:32 »
If you've got the rice, you might get away with the latter.
January 02, 2010, 11:44 »
Silica gel is even better, of course.
January 02, 2010, 11:50 »
Tried and tested?
January 02, 2010, 11:51 »
Oh yes. Used to use it to stop condensation on windows...
Reply #9 on:
January 02, 2010, 12:25 »
Yes, me too, in my old flat.
Reply #10 on:
January 02, 2010, 12:32 »
It doesn't seem such an issue these days, does it.
Reply #11 on:
January 02, 2010, 13:10 »
Not too much, in newer properties. Not sure if wooden window frames help or not.
Reply #12 on:
January 02, 2010, 13:22 »
Sealed double glazing certainly does.
Reply #13 on:
January 02, 2010, 14:01 »
The double glazing is sealed, but the wooden frames could be a bit more draughtproof.
Reply #14 on:
January 02, 2010, 16:00 »
Secondary double glazing had its advantages...
