Author Topic: Sagittarius A*: Peering Into The Heart of Darkness  (Read 716 times)
« on: January 13, 2010, 02:16 »
http://chandra.harvard.edu/photo/2010/sgra/
Astronomers have long known that the supermassive black hole at the center of the Milky Way Galaxy, known as Sagittarius A* (or Sgr A* for short), is a particularly poor eater. The fuel for this black hole comes from powerful winds blown off dozens of massive young stars that are concentrated nearby. These stars are located a relatively large distance away from Sgr A*, where the gravity of the black hole is weak, and so their high-velocity winds are difficult for the black hole to capture and swallow. Scientists have previously calculated that Sgr A* should consume only about 1% of the fuel carried in the winds.
Re: Sagittarius A*: Peering Into The Heart of Darkness
« Reply #1 on: January 13, 2010, 09:31 »
The most fascinating area of our entire galaxy!  There is so much to learn about it.
« Reply #2 on: January 13, 2010, 13:05 »
indeed, I'm part of team surveying the Galactic plane with the Arecibo telescope, exciting stuff.
