Here's a comprehensive list of all the tools you'll ever need; and their uses.
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "Ouch..."
ELECTRIC HAND DRILL:
Normally used for spinning pop rivets in their holes until you die of old age.
PLIERS:
Used to round off bolt heads.
HACKSAW:
One of a family of cutting tools built on the Ouija-board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
MOLE GRIPS:
Used to round off bolt heads. If nothing else is available they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for setting various flammable objects in your workshop on fire. Also handy for igniting the grease inside a wheel hub you want to extract the bearing race from.
WHITWORTH SOCKETS:
Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16" or 1/2" socket you've been searching for the last 15 minutes.
HYDRAULIC FLOOR JACK:
Used for lowering a vehicle to the ground after you have installed your new disk brake pads, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG DOUGLAS FIR 2X4:
Used for levering an vehicle upward off a hydraulic jack handle.
TWEEZERS:
A tool for removing wood splinters.
TELEPHONE:
Tool for calling your neighbour to see if he has another hydraulic floor jack.
SNAP-ON GASKET SCRAPER:
Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog poo off your boot.
BOLT AND STUD EXTRACTOR:
A tool ten times harder than any known drill-bit, that snaps off in bolt holes you couldn't use anyway.
TWO-TON ENGINE HOIST:
A tool for testing the tensile strength of everything you forgot to disconnect.
CRAFTSMAN 1/2" x 16-INCH SCREWDRIVER:
A large pry bar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS:
See hacksaw.
INSPECTION LIGHT:
The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin", which is not otherwise found under cars at night. Health benefits aside, it's main purpose is to consume 40-watt light bulbs at about the same rate that artillery shells might be used during, say, the first few hours of the invasion of Normandy. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER:
Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
AIR COMPRESSOR:
A machine that takes energy produced in a coal-burning power station 200 miles away and transforms it into compressed air that travels by hose to a Taiwanese pneumatic impact wrench that grips rusty bolts last over tightened 58 years ago by someone at Ford, and neatly rounds off their heads.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 20p part.
HOSE CUTTER:
A tool used to cut hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts not far from the object you intended to hit.
STANLEY KNIFE:
Used to open and slice through the contents of cardboard boxes delivered to your front door; works particularly well on contents such as upholstery, software, liquids in plastic bottles, magazines, refund cheques, and rubber or plastic parts.
DAMMIT TOOL:
Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs. It is also the next tool that you will need.
EXPLETIVE:
A balm, usually applied verbally in hindsight, which somehow eases those pains and indignities following our every deficiency in foresight.
JESUS-CLIP OR SPRING:
Small clip or spring you are trying to install when it suddenly goes flying across your garage to be lost forever and you say "Jesus, where did that go?" These parts are usually not sold separately so you will have to buy the complete assembly at 100 times the cost of the clip or spring itself. You console yourself by thinking now you have extra parts on hand. In reality you will never again use anything off this assembly. It will occupy a shelf in your garage until you die and someone cleaning out your garage throws it away, asking "Why on earth did he have this laying around?
