Author Topic: AVG flagging Spotify as a virus  (Read 5904 times)
« on: January 19, 2010, 01:21 »
A friend rang me this evening to see if I knew why AVG was saying there was a virus when he tried to run Spotify.
He couldnt stop it popping up when he opened Spotify or played a new track even when clicking Ignore or Add to Exceptions.
I tried it on mine and it was doing the same thing.
To add it to the exceptions, Spotify have said that its definately not a virus, you need to add it to the exceptions in the AVG User Interfaceby right clicking on AVG and selecting Open AVG User Interface, then double left click on Resident Shield and left click on the Manage Exceptions button at the bottom left of the page.
Click on Add Path on the right side of the new window and browse for C/Program Files/Spotify
Tick the box and click Apply and that should fix it.
Re: AVG flagging Spotify as a virus
« Reply #1 on: January 19, 2010, 01:41 »
I've not known anyone else to have this problem, new configuration issue with AVG perhaps?
« Reply #2 on: January 19, 2010, 04:30 »
It only seems to have been doing it since the latest definition updates from the last couple of days Sam. Lots of posts about it on the net.
« Reply #3 on: January 19, 2010, 14:44 »
I had exactly the same problem more than a year ago Sandra.  I thought that I had downloaded Spotify from a rogue site and decided to uninstall it.  I've since dumped AVG too.   :)
« Reply #4 on: January 19, 2010, 23:42 »
good call on the later.... but I guess you haven't dumped it for Linux...  :cry:
Offline JK
« Reply #5 on: January 29, 2010, 22:01 »
Just posted a new problem AVG 9.0. Used to use AVG 8.5 without problem.
AVG 9.0 has major problems. Solved mine with MSE. ::)
« Reply #6 on: January 29, 2010, 22:02 »
AVG is having a bad run at the moment.
Offline JK
« Reply #7 on: January 29, 2010, 22:21 »
Yes Simon AVG 9.0 is not fit for use.
Just search and take a look. I would recommend MSE.
Yes microsoft is better. AVG 8.5 Great 9.0 not fit for use.
« Reply #8 on: January 29, 2010, 22:42 »
MSE seems to have a good reputation.  Oh well, it's about time MS has something good to offer!   ;D
« Reply #9 on: January 29, 2010, 22:46 »
Their previous attempts at security have been a little half baked, but MSE seems to tick all the boxes.
Offline JK
« Reply #10 on: January 29, 2010, 23:50 »
Simon will give MSE 9/10 .
Offline JK
« Reply #11 on: January 29, 2010, 23:51 »
Found problems that AVG and avira missed.
Offline JK
« Reply #12 on: January 29, 2010, 23:54 »
It's a shame that AVG 9.0 is so bad with magazines falling over to give it a number one review.
« Reply #13 on: January 30, 2010, 00:14 »
I finally dumped AVG last year after suffering a number of FPs.  This year it's Kaspersky IS 2010 (3 licences), but so far that's also proving to be something of a turkey.
So, today I was tempted to take up Giveawayoftheday.com's generous offer of Online Armor++  However, it seems a DDoS attack has blown them out of the water.  Life's a botch.   :(
« Reply #14 on: January 30, 2010, 00:16 »
I've had no problems with F-Secure Internet Security 2010.  Good value for a 3 machine licence too.  :thumb:
