Author Topic: 3-D Gaming Is Waiting for Its Avatar  (Read 7609 times)
Re: 3-D Gaming Is Waiting for Its Avatar
« Reply #15 on: January 24, 2010, 19:09 »
It is for the optician. ;D An average visit costs me around £1200!
« Reply #16 on: January 24, 2010, 19:17 »
:horror:  I thought my Raybans were expensive!
« Reply #17 on: January 24, 2010, 19:28 »
yikes!
« Reply #18 on: January 24, 2010, 19:31 »
Varifocals
Computer glasses (worth the investment give the hours I sit in front of a monitor)
Sunglasses
Driving glasses
(sometimes) Reading glasses.
I do wonders for Nikon's turnover.
« Reply #19 on: January 24, 2010, 19:37 »
separate computer / driving? Is the prescription different?
How do you keep track of all of them? Or do Nikon fit a radio transmitter too?  :laugh:
« Reply #20 on: January 24, 2010, 19:43 »
 :)x
« Reply #21 on: January 24, 2010, 23:17 »
I'ver not heard of computer glasses either. Surely they are similar to reading glasses?
« Reply #22 on: January 24, 2010, 23:20 »
are they polarizing?
« Reply #23 on: January 25, 2010, 00:28 »
If they use those polarising glasses like they do at the 3D Imax screens then I cant see the problem. They arent uncomfortable to wear and as it will be a long time before everything is in 3D, as it is for HD now and as it was for colour when that first came out, then a couple of hours an evening would be no problem at all for most people.
I cant see why they would need new TVs or extra equipment if current SD DVD players can do 3D using the red/blue or green glasses then why cant the polarised glasses do the same thing. Its only if they are going for the shutter type of glasses or the no glasses 3D TVs that you should need new equipment. Given the extra cost that would involve I would happily go wit the polarised glasses method  :)
« Reply #24 on: January 25, 2010, 01:10 »
Its not just the DVD - its the emission.
The emission from the screen has to change polarisation - so you can't just add the glasses. I'm pretty sure that the average screen has some degree of polarisation but it should constant over the whole screen. My life is all about polarisation these days... though normally at radio wavelengths.
« Reply #25 on: January 25, 2010, 10:00 »
Driving glasses are just my distance prescription, Sam. They don't suffer from the same peripheral distortion that varifocals do. Computer glasses are set at my eye-to-monitor distance, so the eye is relaxed when reading, it's the same principle as reading glasses, but with a longer focal length, about 1.5 dioptres different.
« Reply #26 on: January 25, 2010, 13:45 »
Thanks for the explanation Rik.
« Reply #27 on: January 25, 2010, 13:56 »
ah that makes sense.
« Reply #28 on: January 25, 2010, 16:40 »
And money for the optical industry. :) I doesn't help that I like Nikon C-Max lenses, which are about as expensive as you can get.
« Reply #29 on: January 25, 2010, 16:42 »
Waybans wool.    8-)
