April 19, 2025, 06:38
Forum Information & Policies
Website Discussion & Suggestion Box
I Dunno
Topic: I Dunno (Read 9061 times)
I Dunno
January 26, 2010, 09:12 »
This smiley is broken.
This one isn't.
Re: I Dunno
January 26, 2010, 09:14 »
Both are fine here, Rod. Have you tried clearing your cache?
Re: I Dunno
January 26, 2010, 09:21 »
Watch the first one closely, Rik. There are one or two broken frames. It's the same on three different machines, so unlikely to be due to a glitch in the cache.
Re: I Dunno
January 26, 2010, 09:44 »
I'll upload the second one and see if that helps, Rod.
Re: I Dunno
January 26, 2010, 09:54 »
It doesn't... One for Simon as I can't access the server.
Re: I Dunno
January 26, 2010, 10:00 »
You can replace one smiley with another, Rik. Rename the new one 'dunno2', then upload it. Make the smiley code for the old one : dunno2 :, and change the new smiley to : dunno :, then make the old one Hidden, and I'll remove it later.
Re: I Dunno
January 26, 2010, 10:04 »
I did that, the problem was it had the same file name, so the original file was used.
Now sorted...
Re: I Dunno
January 26, 2010, 10:25 »
Re: I Dunno
January 26, 2010, 14:06 »
Could you change it back please? You've made my original post look stoopid now.
Re: I Dunno
Reply #9 on:
January 26, 2010, 14:12 »
That's what you get for complaining. ;devil:
Re: I Dunno
Reply #10 on:
January 26, 2010, 14:23 »
I see you're having a bit of trouble with your colon again, Simon.
Re: I Dunno
Reply #11 on:
January 26, 2010, 14:38 »
Yes, he was running his car on methane this morning.
Re: I Dunno
Reply #12 on:
January 26, 2010, 16:56 »
Infamy!
Re: I Dunno
Reply #13 on:
January 26, 2010, 17:07 »
Notoriety...
Re: I Dunno
Reply #14 on:
January 26, 2010, 18:08 »
Just as bad!
I Dunno
