Author Topic: buying Domain and Email  (Read 6607 times)
Offline GSS
    • artzone4u.com
« on: January 27, 2010, 20:28 »
anyone know a good site to get Domain and Email i use yahoo small business at this time
why i need to move from yahoo is if i email them here they do not get back to me and if i ring them it costs a lot has i got to ring the USA from the UK
All and any Suggests welcome even if the company not in the UK
« Last Edit: January 27, 2010, 20:38 by GSS »
www.artzone4u.com
banner coming soon
Re: buying Domain and Email
« Reply #1 on: January 27, 2010, 21:16 »
We use www.123-reg.co.uk for the forum, GSS, and I believe www.1and1.co.uk are OK too.
« Reply #2 on: January 27, 2010, 21:25 »
Well, a good place to start might be IDnet who sponsor this forum.  I can also recommend 123-Reg, whose prices are very competitive.
Once you've bought a domain, you might also consider using just an email-only service like SimplyMS, which I've used with a couple of my domains for the past few years without problems.
Above all, remember that 'cheap' doesn't always mean 'reliable'.
Good luck!   :)
Offline GSS
    • artzone4u.com
« Reply #3 on: January 28, 2010, 08:45 »
Thank you i have a look soon has i can
www.artzone4u.com
banner coming soon
Offline GSS
    • artzone4u.com
« Reply #4 on: January 28, 2010, 08:55 »
ok had a bit of time so i had a look and at is time i think www.123-reg.co.uk willl be the best
www.artzone4u.com
banner coming soon
Offline GSS
    • artzone4u.com
« Reply #5 on: January 28, 2010, 19:00 »
ok i had a good look at  www.123-reg.co.uk and im now 98% i will go with then now
now if i go with them to i get a help line phone number i can ring if i need to
www.artzone4u.com
banner coming soon
« Reply #6 on: January 28, 2010, 19:04 »
I don't know for them, you do with 1&1. It might also be worth a look at Purplecloud.
Offline GSS
    • artzone4u.com
« Reply #7 on: January 28, 2010, 19:42 »
ok thank you for the help i go have a look at Purplecloud soon has i get time
www.artzone4u.com
banner coming soon
