Author Topic: Vista SP2  (Read 2607 times)
Vista SP2
« on: February 08, 2010, 22:51 »
I installed vista SP2 tonight on my Desktop
After rebooting I cannot connect to the internet.  All other pcs  are connected but when I go into my LAN it says "unidentified network"
I then thought I would use my wireless connection but when I tried to connect it said somebody is using the same ip address.
Now when I check my network it says "Multiple Networks"
I've tried to rename the network to the name I gave it when I set it up but it won't let me type anything
Re: Vista SP2
« Reply #1 on: February 09, 2010, 00:22 »
Is the router seeing the PC when connected by Ethernet cable, Lona?
Re: Vista SP2
« Reply #2 on: February 09, 2010, 21:40 »
I'm not sure Simon, all I can tell you is the other 3 pcs have a connection.  I did pull the router out and left it for a few minutes and plugged it back in.
I've uninstalled sp2 and all is back to normal.  I think I'll do without sp2.
Re: Vista SP2
« Reply #3 on: February 09, 2010, 21:59 »
Rik is your expert here, but if you log into the router interface (you'll have to tell us what it is if you need to know how), it should tekk you if it's connected to the computer.  Then you'll know if it's connected but just not to the Internet, or not connected at all.
Re: Vista SP2
« Reply #4 on: February 10, 2010, 00:16 »
SP2 shouldnt cause a problem as I have it installed on mine and other Vista PCs with non of the problems that you are having Lona.
If you decide to install it again and have the same problem then I suggest going into the networks settings part and telling it to reset the network adaptor, that should resolve any IP address issues.
Re: Vista SP2
« Reply #5 on: February 10, 2010, 01:03 »
firewall software incompatibility with SP2?
Re: Vista SP2
« Reply #6 on: February 12, 2010, 19:00 »
I think you could be right there, Sam.  I installed sp2 on my son's laptop and it was fine.  I have AVG so that could have been the culprit.
Re: Vista SP2
« Reply #7 on: February 12, 2010, 21:06 »
AVG seems to be a culprit in lots of things recently.
Re: Vista SP2
« Reply #8 on: February 13, 2010, 02:21 »
yeah.. I dont think they are keeping up-to-date the mass amount of windows updates...
Re: Vista SP2
« Reply #9 on: February 13, 2010, 08:22 »
That's why I've dumped AVG on all my computers.  Sadly it's had its day and now seems to have turned into a bit of a menace.   :(
Re: Vista SP2
« Reply #10 on: February 13, 2010, 11:20 »
We have certainly heard of a few instances on here of it causing various problems lately.
Re: Vista SP2
« Reply #11 on: February 13, 2010, 19:54 »
Thanks guys,  I might change to Avast which are on the other pcs in the house.
Re: Vista SP2
« Reply #12 on: February 13, 2010, 20:10 »
yeah sounds like a good idea.
Re: Vista SP2
« Reply #13 on: February 13, 2010, 22:27 »
Avast is very good Lona.  It's much less intrusive than AVG and a voice tells you "virus database updated".  It found a couple of viruses during the year I had it installed although one was a false positive.   :gofor: Lona.
