Author Topic: Ubuntu resolution problem  (Read 1699 times)
Offline jww41005
« on: February 12, 2010, 12:52 »
I've just unistalled Ubuntu 9.10 after not being able to change the resolution. It was stuck on 800x600.
I looked on the Ubuntu forum, which didn't seem to have a simple solution.
Pity!
John
If it works, don't fix it
Re: Ubuntu resolution problem
« Reply #1 on: February 12, 2010, 14:03 »
I'm sure Sam will have something to say about that!  Check back later.  He's in Canada at the moment, so 7 hours behind us.  :)
« Reply #2 on: February 12, 2010, 14:50 »
so it was locked in system -> preferences -> display menu item?
hmmm. If that didn't work I could have told you how to do it the harder way I guess.
What type of graphics card do you have?
Offline jww41005
« Reply #3 on: February 12, 2010, 18:01 »
Hi fellas!
It would have been better to say that 800x600 was the highest resolution available.
The graphics card is: SiS Mirage 3
My OS is Vista Home Basic, which doesn't have any resolution probs.
It would be nice to find a simple solution to this.
Sam, are you in Canada for the Winter Olympics?
Cheers
John
« Reply #4 on: February 13, 2010, 02:41 »
having looked around a bit there appears to be quite a few threads having problems with this specific graphics card. Weird really given the hardware support that Ubuntu has now. You seem to have gotten further than others though.
A couple of suggestions though...
If you fancy opening up a terminal... (Applications ->Accessories -> Terminal)... type:
Code: [Select]
gksu displayconfig-gtk
It will ask you for your password as you are running an admin tool... then you should be able to change it.
If you want to know more / try a few other graphics things the Ubuntu howto on this can be found: http://ubuntuforums.org/showthread.php?t=83973
Oh and...
No, but I will watch a few bits and pieces. I'm working in Calgary at the for University for 2 years (been here 6months) on software for the Square Kilometre Array (to be the worlds largest telescope.
Offline jww41005
« Reply #5 on: February 13, 2010, 10:45 »
Thanks for that, Sam,
I will have a look at it when I'm in the mood for it. Maybe this weekend.
Btw, a student of mine is involved in developing and maintaining the Spanish version of Linux, which is called 'Guadalinex'. I had a look at it on my laptop, and I had the same resolution problem!!
Your job sounds interesting. I saw a great documentary the other week about the Hubble and the James Webb telescope.
Cheers
John
« Reply #6 on: February 13, 2010, 16:36 »
probably a more fundamental driver issue then... you've been unlucky with that one.
The job is indeed interesting, if not a bit confusing... I'm mostly working on the statistics of source detection - its cool to be part of such a huge multi-billion pound project.
Offline jww41005
« Reply #7 on: February 13, 2010, 17:29 »
Yep! It's a driver problem.
Never mind.
SiS Mirage 3 and Linux simply aren't compatible :brickwall:
