Author Topic: Free Today Only - Backup Software  (Read 2445 times)
« on: February 17, 2010, 09:53 »
Psssst!  GiveawayOfTheDay.com is giving away Paragon System Backup 2010 Special Edition, for TODAY ONLY.
I can't recommend Paragon software highly enough, but as it's a 140MB download I'd start around about now, if I were you.   ;)
Re: Free Today Only - Backup Software
« Reply #1 on: February 17, 2010, 10:48 »
Thanks, Rod.  :thumbs:
« Reply #2 on: February 17, 2010, 11:53 »
Thanks Rod.  Do you actually have to install it today as well, or can the download be saved until I have more time?
« Reply #3 on: February 17, 2010, 11:54 »
Install today, Simon.
« Reply #4 on: February 17, 2010, 11:54 »
Bugger.
« Reply #5 on: February 17, 2010, 12:02 »
Indeed.
« Reply #6 on: February 17, 2010, 12:22 »
Once you've installed the software and registered it with Paragon, save the unique reg key and (unwrapped) install package for installation on another machine, should you ever need to upgrade your hardware.  You'll need one reg key per installation.
If you're installing on more than one machine, save the original GiveawayOfTheDay (wrapped) download package and port it to the other boxes via CD, or USB key.  No need to download it every time.  However, you must unwrap, install and thereby obtain your reg key for each installation TODAY.  Don't leave it too late in the evening, as Paragon's reg key server takes a battering at times like this.
