Author Topic: Most Windows 7 PCs max out memory  (Read 1895 times)
« on: February 19, 2010, 21:59 »
Good News: Windows 7 works well. Bad News: Because it's a resource whore.   ::)
LINK
Re: Most Windows 7 PCs max out memory
« Reply #1 on: February 19, 2010, 22:09 »
I'm sure I read a similar article recently, which debunked that theory.
« Reply #2 on: February 19, 2010, 22:58 »
That would have been THIS one.   ;D
« Reply #3 on: February 19, 2010, 23:06 »
:)x
« Reply #4 on: February 20, 2010, 05:46 »
LINK
not that shocking then... then again I'm a resource whore right now... I'm currently running software on 10 processors and using up about 24GB of RAM. Nice. Can't wait to get my software installed on the other 40 processors...   :devil:
« Reply #5 on: February 20, 2010, 08:25 »
 :hee-hee:
« Reply #6 on: February 20, 2010, 11:30 »
It's going to make you feel inadequate in the future, Sam. ;D
« Reply #7 on: February 20, 2010, 17:04 »
well we are ramping up to having to deal with 1TB/second .... inadequate indeed!
We now have a 50TB hard drive... :-)
« Reply #8 on: February 20, 2010, 17:09 »
I hope it never crashes! :x:
« Reply #9 on: February 20, 2010, 17:30 »
its raided... so should be fine.... plus all of our raw data is stored on external disks and tape. :-) The only problem is if it did crash it takes a few days todo a fschk... and then would take a week or so if we needed to put the data back on there!
« Reply #10 on: February 20, 2010, 17:31 »
And I think 10 minutes is bad. ;)
« Reply #11 on: February 20, 2010, 18:01 »
lol
