November 27, 2024, 22:43
Technical Help & Discussion
General Tech Discussion, News & Q&A
We're doing 6 cores!
Topic: We're doing 6 cores! (Read 1330 times)
March 12, 2010, 14:29 »
The new Core i7-980X Extreme Edition (codenamed "Gulftown") is a six-core CPU that promises a whole new level of performance.
http://www.pcmag.com/article2/0,2817,2361144,00.asp
Re: We're doing 6 cores!
March 12, 2010, 14:50 »
cool.
We were talking about getting 8 core machines the other day... more and more ram will be needed to take advantage of these chips.
March 12, 2010, 15:39 »
Now all we have to wait for is the software to catch up...
March 12, 2010, 16:24 »
You wouldn't need central heating with that in the room!
March 12, 2010, 16:29 »
True, but think of the cost of the air con in summer...
March 12, 2010, 16:32 »
Summer? Oh yes, I remember that! It's too bleedin' hot!
March 12, 2010, 16:34 »
Well, occasionally...
March 13, 2010, 05:43 »
Quote from: Rik on March 12, 2010, 15:39
ah, wait for what?
all of the current operating systems, even friggin windows, can deal with multiple cores - its just sends jobs to different cores... not many of the software packages will be using them in a parallel threaded manner but they will be dynamically arranging resources so you maximise the usage of them.
March 13, 2010, 10:36 »
Though a program like Photoshop would really benefit from being able to use multiple cores.
Reply #9 on:
March 13, 2010, 16:04 »
im not sure if the newer versions dont... but isn't it more of a memory issue than raw processing speed? Of course a better solution would be for graphical editors to run on the GPU - since surely they are just doing matrix algebra.
Reply #10 on:
March 13, 2010, 16:05 »
You certainly can't give PShop too much memory, Sam, though I remember a time when it choked if you had more than 1GB installed.
