Author Topic: Bad BitDefender Update Clobbers Windows PCs  (Read 1373 times)
« on: March 21, 2010, 21:06 »
Users of the BitDefender antivirus software started flooding the company's support forums Saturday, apparently after a faulty antivirus update caused 64-bit Windows machines to stop working. The company acknowledged the issue in a note explaining the problem. 'Due to a recent update it is possible that BitDefender detects several Windows and BitDefender files as infected with Trojan.FakeAlert.5,' the company said. The acknowledgment came after BitDefender users had logged hundreds of posts on the topic. Some complained of being unable to reboot their systems."
http://tech.slashdot.org/story/10/03/21/1515230/Bad-BitDefender-Update-Clobbers-Windows-PCs
Re: Bad BitDefender Update Clobbers Windows PCs
« Reply #1 on: March 21, 2010, 22:49 »
 :doh:
« Reply #2 on: March 21, 2010, 22:52 »
have windows, will have problems.
« Reply #3 on: March 21, 2010, 23:25 »
« Reply #4 on: March 22, 2010, 10:45 »
This happened to me on both desktops when I was using AVG.  I ended up dumping AVG and switching to F-Secure and Avast.
« Reply #5 on: March 22, 2010, 13:31 »
Oh the joys of antivirus.
« Reply #6 on: March 22, 2010, 15:48 »
Marginally better than the joys of virus, though...
« Reply #7 on: March 22, 2010, 16:28 »
I've used BitDefender, and found it one of the most unobtrusive of the suites I've tried, in that it didn't slow things down, or use much in the way of resources.  The reason I stopped using it was because it flagged up so many false positives when running a scan.
« Reply #8 on: March 22, 2010, 19:19 »
That's a moot point Rik.  I once had a machine that refused to boot up after a MacAfee update and nothing could solve it.  I ended up removing the hard drive to extract the data to another machine and binning the rest of the tower.  I could have easily removed a virus.   :dunno:
« Reply #9 on: March 22, 2010, 19:39 »
Some are just impossible to remove.  I often wonder about all of these anti-virus softwares.  They work perfectly, until they let something through, then your computer is screwed.   :-\
« Reply #10 on: March 22, 2010, 21:40 »
Yes, I have had those thoughts too.   :bawl:
« Reply #11 on: March 23, 2010, 00:05 »
I tell you what... the future... its LINK    8-)
Basically with a good firewall and educated users it should never really be a problem.
« Reply #12 on: March 23, 2010, 00:22 »
:aarrgh:
« Reply #13 on: March 23, 2010, 08:59 »
 :lol2:
