Author Topic: A Friend of mine downloaded PPTV ??  (Read 3726 times)
Offline TOFFEEMAN1878
« on: March 29, 2010, 17:17 »
Anyone one know how to remove it ,it comes with lots of baggage!.....Jim
Re: A Friend of mine downloaded PPTV ??
« Reply #1 on: March 29, 2010, 17:54 »
A quick Google doesn't reveal much on removal, sorry. I take it using the standard Windows Add/Remove doesn't do the job?
« Reply #2 on: March 29, 2010, 21:56 »
Hi Jim,
If the conventional Add / Remove Programs method doesn't work, you could try Revo Uninstaller.  That link is to the free version, but there's also a 'stronger' pro version available.
« Reply #3 on: March 29, 2010, 23:18 »
Revo free should get rid of it with a deep scan it has worked for me with worse programs
