Author Topic: Windows Update for XP will not install?  (Read 1675 times)
Offline TOFFEEMAN1878
« on: March 31, 2010, 13:06 »
(Cumulative Security Update for Internet Explorer 8 for Windows XP (KB980182) Has not been installed )
That's the message I get even if I try to install from the Windows Update site!  Anyone Else?
Re: Windows Update for XP will not install?
« Reply #1 on: March 31, 2010, 13:36 »
Without Googling to see if it's a common issue, it might be worth trying to install it with your anti-virus and other security turned off, Jim.  Turn it back on after, of course!
« Reply #2 on: March 31, 2010, 22:04 »
Cheers, Simon will try that!
