Author Topic: Start up issue  (Read 6075 times)
Start up issue
« on: April 01, 2010, 17:38 »
My computer has developed a strange problem, which used to only happen once in a while, but now seems to happen all the time.  When I start my machine from cold, the post beep sounds, and the monitor fires up, but all I get is a blank screen.  I've sat for ages, thinking it might be installing updates, or something, but I don't think it is, and I end up having to press the reboot button, at which point, I get the 'Windows failed to start...' screen, with the options of Safe Mode, LKGC, etc, and Start Windows Normally highlighted.  I wait the 30 seconds, as the USB keyboard isn't 'live' at that point, and Windows fires up perfectly each time.  I have no additional drives or hardware connected, and no disc in the CD drive.  It's an annoyance, rather than a major issue, but any ideas as to what it might be?
Re: Start up issue
« Reply #1 on: April 01, 2010, 17:41 »
I had a similar fault, and it was the graphics card not booting up correctly.
Re: Start up issue
« Reply #2 on: April 01, 2010, 17:48 »
Really?  Hmm....  How did you fix it?
Re: Start up issue
« Reply #3 on: April 01, 2010, 17:51 »
New card. :(
Re: Start up issue
« Reply #4 on: April 01, 2010, 18:04 »
Bugger.  I'll live with it.
Re: Start up issue
« Reply #5 on: April 01, 2010, 18:08 »
I take it you're not under warranty? It might be worth re-seating the card.
Re: Start up issue
« Reply #6 on: April 01, 2010, 18:33 »
It might be, worth reseating, that is.  Could be a lot of dust in there.  I'll have a poke about over the weekend.  :)
Re: Start up issue
« Reply #7 on: April 01, 2010, 18:35 »
Make sure the fan is clean while you're in there.
Re: Start up issue
« Reply #8 on: April 01, 2010, 18:40 »
The annoying thing is, I have a cleaner in once a fortnight.  She obviously isn't doing her job properly!   >:(
Re: Start up issue
« Reply #9 on: April 01, 2010, 18:41 »
Write a new contract!
Re: Start up issue
« Reply #10 on: April 01, 2010, 18:42 »
I think I'll have to.  She spends her whole hour cleaning the guttering, and never gets anything else done.
Re: Start up issue
« Reply #11 on: April 01, 2010, 18:53 »
She should at least flush the main drains while she's at it.
Re: Start up issue
« Reply #12 on: April 01, 2010, 20:23 »
You can try deleting the drivers and reboot
It should install a new driver
the driver could be corrupted in some way
Re: Start up issue
« Reply #13 on: April 01, 2010, 20:47 »
Possible, Dave.
Offline Baz
Re: Start up issue
« Reply #14 on: April 01, 2010, 21:05 »
a cleaner with a dirty fan?????????????? ;D
