April 30, 2025, 05:37
Technical Help & Discussion
LG Flatron Monitor L1915S
Topic: LG Flatron Monitor L1915S (Read 6848 times)
nash017
New Member
April 11, 2010, 22:41 »
The green power light goes on for a split second and then goes off, :dunno:and Monitor does not come on
Any ideas please.
Re: LG Flatron Monitor L1915S
April 11, 2010, 23:25 »
I'm sure there will be some other opinions, but have you checked the connections between the PC and the monitor?
Sandra
Ultimate Member
April 12, 2010, 00:05 »
Is this a new monitor ?
Is it DVI and VGA and have you switched it to the correct input to match your pcs output ?
April 12, 2010, 10:58 »
Do you have a spare monitor that you can check the card's output with?
nash017
New Member
April 12, 2010, 19:23 »
Hi All, Checked connections between pc and monitor, no probs.The monitor is VGA and no switch. Have checked card and no problem. Have stripped the monitor down and it looks like a few of the capacitors have leaked. Have taken a few pictures, but don't think I can upload them here.
nash017
New Member
April 12, 2010, 19:24 »
No monitor is not new, was made in '05
April 12, 2010, 20:09 »
You should only have to make a few more posts to enable you to upload attachments on here.
April 13, 2010, 09:59 »
Or upload to somewhere like Flickr and link to them here.
April 13, 2010, 10:24 »
He can't link either yet, Rik. Two more posts should do it.
Reply #9 on:
April 13, 2010, 10:40 »
Of course.
Baz
Established Member
Reply #10 on:
April 13, 2010, 18:14 »
so many posts before you can upload?? its like saving supermarket stamps or something
Reply #11 on:
April 13, 2010, 18:18 »
It's due to spammers, Baz.
Baz
Established Member
Reply #12 on:
ah safety first eh
Reply #13 on:
April 13, 2010, 18:20 »
Unfortunately, yes.
Reply #14 on:
April 13, 2010, 18:24 »
If new members want to post a link, they will need to PM a member of staff, just for their first few posts.
