Author Topic: Download/Save to problem  (Read 1492 times)
Offline Big_Boss
« on: April 20, 2003, 10:46 »
Hi,
A few days ago i clicked a file and went to download and then save to, and i think i ticked/unticked a box by accident. Now when i click on links to zip files they download automatically without prompting me where to save it.
Quite a bad description but hopefully you can help me  :-\
Boss
Re:Download/Save to problem
« Reply #1 on: April 20, 2003, 11:40 »
Are you on Windows 98 or XP Big_Boss? Here is the procedure for 98 anyway ...
Open My Computer (or any other folder)
Click View | Folder Options
Click the File Types tab
Find the ZIP type in the Registered File types list.
Click the Edit button
Tick the Confirm open after download box
Press OK
I think it's similar in XP :)
Offline Big_Boss
« Reply #2 on: April 20, 2003, 13:05 »
Yup im on XP and its exactly the same.
Followed the steps and its working fine again. :welldone:
Thanks, :clever:
Boss
