April 08, 2025, 10:36
Technical Help & Discussion
Add / Remove Quickie
Topic: Add / Remove Quickie (Read 1639 times)
April 21, 2003, 10:11 »
I have a list of about 20 Windows XP Hotfixes (updates) in my Add / Remove Programs list, but no file sizes or other details.
Do these have to stay there, or is it safe to remove them to tidy up the list?
chorleydave
Re:Add / Remove Quickie
April 21, 2003, 14:54 »
Hi, Simon.
If you have Regcleaner on your PC (Freeware available on the CNET Download site) the "Uninstall Menu" tab will allow you to remove them from the list without uninstalling the program/patch. I use it all the time to keep my list tidy.
Hope this helps.
April 21, 2003, 15:38 »
Thanks Dave. I do have Reg Cleaner, and that worked a treat!
