Author Topic: Samba Configuration with Webmin  (Read 1445 times)
« on: April 22, 2010, 04:21 »
You may have read my recent article "Easy Samba Setup," which illustrated just how easy it can be to set up the Samba file and print server. Yes, that task can be easy, but the method I outlined does require you to take advantage of the command line. There are a lot of users who shy away from the command line as if it were the plague. For those users there are options. One of those options is the Samba tool from the Gadmin suite of tools.
http://www.linux.com/learn/tutorials/299651-samba-configuration-with-webmin
