Author Topic: problem  (Read 4840 times)
Offline nilsatis
problem
« on: April 25, 2010, 17:21 »
I have a problem on my laptop, firstly, the Internet just closes down, no warning just shuts off, I have been getting pop up ads on pages opening up on their own, and when I use google and search I do not get my search I get adverts.
I have run Malwarebytes and it found nothing, Avast found some stuff and I got rid, but the big worry is Spybot, when it searches it finds Zango(?) but halfway through the scan my laptop keeps shutting down before I can do anything, I have looked in programmes and cannot see any Zango stuff, any help??
Re: problem
« Reply #1 on: April 25, 2010, 17:23 »
Get hold of a copy of Super AntiSpyware, boot into safe mode and try scanning from there.
Re: problem
« Reply #2 on: April 25, 2010, 18:15 »
The free version of PrevX may also be useful by the same method.
Offline nilsatis
Re: problem
« Reply #3 on: April 26, 2010, 18:14 »
Superantispyware cleaned most of it up, but the search is still going to adverts, I tried a free version of PrevX but they want money to fix problem.
Re: problem
« Reply #4 on: April 26, 2010, 18:19 »
It might be quickest to bite the bullet and do a clean installation. :(
Offline Baz
Re: problem
« Reply #5 on: April 26, 2010, 18:53 »
dont know if this is the cause but might be worth looking at.In google home page click Search Settings near top right corner,then SafeSearch Filtering section have a look to see what is selected in there.mine is set on the middle radio button of Use moderate filtering(filter explicit images only-default behaviour). It may have been changed by accident.This is mainly to block sexual content but it may be worth a try.
Re: problem
« Reply #6 on: April 26, 2010, 18:54 »
Good lateral thinking, Baz. :)
Offline Baz
Re: problem
« Reply #7 on: April 26, 2010, 18:57 »
it could be something daft like that Rik.every now and again something changes my google settings back to the part that suggests what you are searching for,I hate it ;D
dont know why it happens either  :dunno:
Re: problem
« Reply #8 on: April 26, 2010, 18:58 »
Gremlins. ;)
Offline Baz
Re: problem
« Reply #9 on: April 26, 2010, 19:06 »
aye,pesky things :laugh: :laugh:
Offline nilsatis
Re: problem
« Reply #10 on: April 26, 2010, 19:33 »
Cheers guys, but no it was set to moderate, the problem is that when I search on google it goes to the results of the search but will not open when I click the page I want it opens Ask Jeeves or some other search engine, Im also getting new windows opening up with Ask Jeeves.
Re: problem
« Reply #11 on: April 26, 2010, 19:41 »
What browser are you using?
Offline nilsatis
Re: problem
« Reply #12 on: April 26, 2010, 19:52 »
IE
Offline Baz
Re: problem
« Reply #13 on: April 26, 2010, 20:12 »
what are you searching for too
Offline Baz
Re: problem
« Reply #14 on: April 26, 2010, 20:14 »
IE has a drop down box in top right hand corner where you can select which search engine to use.have you tried that
