Author Topic: Remote Control Your Linux Desktop Using the iPhone  (Read 1628 times)
Remote Control Your Linux Desktop Using the iPhone: Did you know that you can remotely control your Linux desktop over a local network using the iPhone? Yes you can, and there's no need for you to edit a config file, create a shell script, or even jailbreak your iPhone in order to make it possible. If you are ready, follow these simple steps to remote control your Linux desktop via the iPhone.
http://www.junauza.com/2010/04/remote-control-your-linux-desktop-using.html
note: similar can be done on Android.
Re: Remote Control Your Linux Desktop Using the iPhone
« Reply #1 on: April 25, 2010, 21:49 »
Interesting... 20 views before this reply.
« Reply #2 on: April 25, 2010, 23:01 »
hmmm....
« Reply #3 on: April 26, 2010, 08:59 »
Good old Google. :)
« Reply #4 on: April 26, 2010, 09:29 »
It seems to be picking certain threads though.  :dunno:
« Reply #5 on: April 26, 2010, 09:31 »
I wonder what their algorithm is? Maybe Sam knows.
« Reply #6 on: April 26, 2010, 09:44 »
I certainly don't!
« Reply #7 on: April 26, 2010, 10:09 »
Google thinks, so Google exists? ;D
« Reply #8 on: April 26, 2010, 10:29 »
« Reply #9 on: April 26, 2010, 14:06 »
:dunno: but I expect it possibly something todo either with that or our the twitter feed.
