Author Topic: pop up killer  (Read 7185 times)
pop up killer
« on: April 22, 2003, 10:40 »
hi all
i know its been posted before, but cant find it, so could someone direct me to a good free (cheapskate) pop up ad killer.
cheers   ;D
Re:pop up killer
« Reply #1 on: April 22, 2003, 11:19 »
Here you go Dave >> http://www.panicware.com/product_psfree.html
This is a new version, which IMO, isn't as good as the old version, but it will do the job.
Re:pop up killer
« Reply #2 on: April 22, 2003, 13:38 »
Cheers Simon
Offline bat69
Re:pop up killer
« Reply #3 on: April 22, 2003, 23:49 »
Set it to Aggressive mode ... but you will have to remember to hold down the shift or CTRL key when clicking on links .....
but remember that Pals has NO pop-ups .... so you can disable it while you are browsing Pals    ... note Popup stopper affects the links on Pals and the extra smileys
Re:pop up killer
« Reply #4 on: April 22, 2003, 23:52 »
...note Popup stopper affects the links on Pals and the extra smileys
The old version doesn't, which is why I haven't upgraded to the new one.   ;) 8)
Offline bat69
Re:pop up killer
« Reply #5 on: April 23, 2003, 00:00 »
Smart ar**     I couldn't be bothered to do the smiley :P ... naa more like couldn't in my current state :P
Re:pop up killer
« Reply #6 on: April 23, 2003, 00:06 »
:drunk:  again, Bat?!!  You're getting worse than Adept!
Re:pop up killer
« Reply #7 on: April 23, 2003, 09:31 »
Not quite yet!  :P ::) :go:
Re:pop up killer
« Reply #8 on: April 23, 2003, 11:30 »
The Opera browser comes with a popup killer built-in.
GO ON - YOU CAN ALL YAWN IF YOU WANT TO - I DON'T  MIND.
 ;D ;D ;D ;D
I use Popup Cop when I'm forced to use Internet Explorer.  It has a built-in Cookie Manager, plus loads of other tweaks, and will warn you if a site is trying to download anything to your PC.  It has to be registered after a trial period, but if I type the words "Google Groups", I'm sure you'll know what I mean!
Offline ketamininja
Re:pop up killer
« Reply #9 on: May 03, 2003, 16:55 »
Remember that there are security setting in MS IE. I use these "restrictions" for popups on some sites that I use. Works a treat.
Sometimes it doesn't allow small features of the website to work (javascript links I think), but thats no problem for me on these sites.
Handy if you don't want to clutter up your machine with 3rd party software... I prefer to have a clean a machine as possible!
Re:pop up killer
« Reply #10 on: May 03, 2003, 17:03 »
That's a very useful tip Ketamininja.  I often think that a lot of utility software simply uses facilities which already exist in Windows or IE, but offer a more friendly interface to access them.
Offline ketamininja
Re:pop up killer
« Reply #11 on: May 03, 2003, 17:26 »
Thats true Clive.
They do what you can already do (most of the time). And they sometimes charge you for that!!
Also, remember that 3rd party will take up more resources.
Re:pop up killer
« Reply #12 on: May 03, 2003, 17:31 »
Just noticed your bit under your Avatar   K   yes you have unfortunately to resize it and for some obscure reason it has to be exactly 100 x 100 not just smaller than that ;)
Offline ketamininja
Re:pop up killer
« Reply #13 on: May 03, 2003, 17:39 »
my avatar is something like 300x400 !! (which is usually resized on most forums - they ask for the size to resize)
Think I'll just resize tonight :o
This hijacking threads thing is becoming a habit - heh :-[
Re:pop up killer
« Reply #14 on: May 03, 2003, 22:57 »
Just wait until someone mentions going off TOPIC and see what happens then  K  as that is what our forum is famous for (as well as being extremely helpful and lots of fun) :-*
