Author Topic: Re-booting and strange blue screen??  (Read 3448 times)
« on: May 17, 2010, 12:25 »
This is the sequence that happens at first turning it on,
MB screen with this across the bottom,
Post screen <DEL>: Bios and some another stuff
then, the screen with white writing for devices, but this is all messed up with verifying DMI Pool at the bottom.
then the screen is full of !!!!!!!!!!!!
Then Windows XP normal load screen.
then black screen and the fans speed up as if it's going to load everything.
then a strange black and white step pattern
then it powers off the monitor and keyboard, and the whole thing starts again.
This is what the blue boot screen has on it????
Re: Re-booting and strange blue screen??
« Reply #1 on: May 17, 2010, 12:31 »
It looks like your CMOS memory might have scrambled, Kate. Do you have the motherboard manual?
« Reply #2 on: May 17, 2010, 12:37 »
Hi Rik, yes we do.
We did come across this in our Whirlpool forum.
http://forums.whirlpool.net.au/forum-replies.cfm?t=1288693
It wouldn't surprise me if it was his video card as he has taken the cover off it to help with cooling, but it gets full of dust.  >:(
« Reply #3 on: May 17, 2010, 12:40 »
Have you got a spare card you can try?
« Reply #4 on: May 17, 2010, 12:47 »
No, it's in my computer. Well I guess I can turn this one off and use the laptop.
« Reply #5 on: May 17, 2010, 12:54 »
He did take the battery out on the weekend when it was doing this, didn't make any difference.
But we found the MB manual and he has taken the card out of mine and is installing it in his.
« Reply #6 on: May 17, 2010, 12:57 »
There's usually a jumper to clear the CMOS once you've taken the battery out, Kate. At that point in the boot process it can only really be CMOS or graphics card, so if you change the latter, you will have a pretty good diagnosis.
« Reply #7 on: May 17, 2010, 13:27 »
He is re-installing Windows, and it appears that the card from my computer has done the trick. Which was his old card from his medion computer which I needed after the fan fell of mine.
The card that has caused the problem is a XFX 9800 GTX Black Edition 512mb, which was quite expensive. I'm hoping it can be fixed.  :(
« Reply #8 on: May 17, 2010, 15:02 »
Well someone has found a way of fixing them when all else fails.
http://forums.whirlpool.net.au/forum-replies.cfm?t=1348684
« Reply #9 on: May 17, 2010, 15:19 »
Don't forget to baste it regularly. :)
« Reply #10 on: May 17, 2010, 15:28 »
I think I'll fore go the basting, as I'll like mine crispy.  :bunny-giggle:
« Reply #11 on: May 17, 2010, 15:29 »
