Author Topic: Re:UNMOUNTABLE_BOOT_VOLUME  (Read 6432 times)
Offline Mattieh
« on: May 18, 2010, 14:04 »
Hi,
Every time I turn on my PC it won't start up - it restarts when Windows XP tries to load up.  It came up with the following error message when I tried, unsuccessfully, to run the recovery program:-
UNMOUNTABLE_BOOT_VOLUME STOP:0*000000ED(0*85B949DO, 0*C0000006, 0*00000000, 0*00000000).
I don't have a Windows XP CD.  Is there any way I can rectify the problem without using a Windows XP CD?
Thanks.
Matt.
Re: Re:UNMOUNTABLE_BOOT_VOLUME
« Reply #1 on: May 18, 2010, 14:18 »
Hi Matt and :welcome:
Will it start in safe mode ?
If so you could try running Chkdsk /f from the run box.
I will say it cant run as its in use but will ask if you want to schedule it on the next startup, say yes and reboot.
« Reply #2 on: May 18, 2010, 14:23 »
Hi Matt,  :welcome:
At this stage, I can't add to what Sandra has suggested.
Offline Mattieh
« Reply #3 on: May 18, 2010, 15:47 »
"Hi Matt
I will say it cant run as its in use but will ask if you want to schedule it on the next startup, say yes and reboot."
Thank you. :)
No, it won't start in safe mode unfortunately. :(
« Reply #4 on: May 18, 2010, 15:53 »
This might help, Mattieh, but it does look like you need your XP CD. :(
http://support.microsoft.com/kb/297185
« Reply #5 on: May 18, 2010, 23:54 »
do you have any other bootable disks (windows or otherwise)?
« Reply #6 on: May 19, 2010, 00:52 »
You could download Hirens Boot CD and use that to do various things from that like, FixMBR or run Mini XP to enable you to run CHKDSK /F amongst other things.
http://hotfile.com/dl/36432014/e585b32/9Down.COM_Hirens.BootCD.10.3.rar.html
You will have to wait a bit for the download to start and it may be a bit slow using the free option but its worth getting.
Offline Mattieh
« Reply #7 on: July 05, 2010, 14:28 »
Thanks for the reply.  In the end, I got a neighbour's XP disc to sort it out.  It's absolutely fine now!
Thanks again for taking the time to reply.  Much appreciated.
Matt.
« Reply #8 on: July 05, 2010, 15:37 »
Thanks for letting us know Matt.  :thumbs:
