November 27, 2024, 18:50
Technical Help & Discussion
PC & Console Games and Gaming
Can you use the same disk and serial number to download it on another?
Topic: Can you use the same disk and serial number to download it on another? (Read 5895 times)
Famous16
New Member
May 28, 2010, 18:24 »
Hi guys,
Please I just want to know If you downloaded Warcraft 3 III Reign of Chaos on one computer can you use the same disk and serial number to download it on another?
Regards,
Famous16
Re: Can you use the same disk and serial number to download it on another?
May 28, 2010, 18:25 »
Welcome to Pals.
I can't give you a definitive answer as I don't know the software, but I'd expect that you can't.
May 28, 2010, 18:31 »
I agree, I would have thought one licence, one machine.
Sandra
Ultimate Member
May 29, 2010, 01:54 »
If its installed and registered off line and doesnt need to be activated either online or by phone then it should work OK.
It may cause a problem if one or more are used online later though.
