November 27, 2024, 16:36
Technical Help & Discussion
PC & Console Games and Gaming
PAL games do not play
Topic: PAL games do not play (Read 6790 times)
Famous16
New Member
May 31, 2010, 16:16 »
Hi all,
Please can someone tell me some PAL games do not play or display an all-green screen. What's wrong?
Regards,
Famous16
Re: PAL games do not play
May 31, 2010, 16:27 »
Hi,
Maybe your graphics card isn't compatible? Although, I didn't realise games were PAL or NTSC, I thought they were universal.
May 31, 2010, 16:31 »
No idea, to be honest, I'm not a games player. What console are you using?
June 02, 2010, 05:43 »
PC games are indeed Universal, its only the console ones.
Can you tell us what console you are using and where you are? Though, if you system can read the other region formats then it should be compatible... eitherway I'm confused.
