Author Topic: Recommend for a Anti-Virus program?  (Read 4408 times)
« on: June 01, 2010, 08:43 »
I have been using Avast free anti-virus and have been quite happy, but it seems to be time limited and I'm sick to death of the constant reminders that it's about to expire.
So today it expired and when I tried to download and install it again, it disappeared?? I'm taking that as a hint that I shouldn't re-install it as it will only give me the sh**s further down the track.
I don't really want to go back to AVG, as it gave me the proverbial....... as did Malwarebytes
I've had a look on FileHippo and there doesn't seem to be much choice??
I have Ad-Aware and A-squared, but I want something that runs in the background and keeps me safe. Actually, if you can suggest one that is clean and tidy, I'll marry it.  ;D
Re: Recommend for a Anti-Virus program?
« Reply #1 on: June 01, 2010, 09:31 »
Lol!  Is this on XP, Kate?  If you had Vista, I'd say to try Microsoft Security Essentials, but I'm not sure it runs on XP.  Are you sure you installed the free version of Avast, and not a trial?  I was under the impression that the free version was free without time limits.
« Reply #2 on: June 01, 2010, 09:45 »
Hi Kate. :)
« Reply #3 on: June 01, 2010, 09:50 »
Hi Rik.  :-*
Yes, XP on my PC and Windows 7 on the laptop.
I'm trying to download it again as the earlier tries ended with an empty file?
I'll have to restart to see if it has worked this time, but I'm waiting for A2 to update, takes foreveeeerrrrr.
« Reply #4 on: June 01, 2010, 09:51 »
0 bytes? Odd... You could try the MS offering on the lappy.
« Reply #5 on: June 01, 2010, 10:03 »
Avast had a installation log which I looked at, about 1000 pages of error code 00000 and something about failing to install.
I'm going to run HijackThis and see what's going on. This is running at snail's pace and A2 failed to update fully as well.
« Reply #6 on: June 01, 2010, 10:05 »
Happy hunting. :)
« Reply #7 on: June 01, 2010, 10:27 »
Try a scan with Super Anti-Spyware?
« Reply #8 on: June 01, 2010, 11:20 »
Okay, nothing nasty.
And if I had of paid attention to what the avast installation was actually doing, I would have realised that it was UNinstalling it first....so when I went looking for it, I couldn't understand why it wasn't there.  :blush:
It's now installed, and it is the FREE version.
So let's just pretend that this thread doesn't exist and I'll crawl away very quietly, and no one will know I've been here......  :shh:
« Reply #9 on: June 01, 2010, 11:21 »
Offline Camstop
« Reply #10 on: June 01, 2010, 11:25 »
I seem to get on ok with Avira Antivir and it mostly just sits in the background.
The only thing is it sticks 1 pop up add on each day at a certain time but you just click it off and soon get used to it.
Im sure there would be a way of disabling the add but i haven't looked into it.
Another essential is CCleaner is you haven't already got it.
« Reply #11 on: June 01, 2010, 11:29 »
Hi Cammy, how you doing?
Offline Camstop
« Reply #12 on: June 01, 2010, 14:22 »
All fine in cam-land Si.
Did you ever change your mobile?
I think the best thing is to buy, then not look for 18 months  ;D
« Reply #13 on: June 01, 2010, 15:02 »
It's the only way, Cammy. That or we lock up his credit card. ;D
« Reply #14 on: June 01, 2010, 15:08 »
Still got the BlackBerry at the moment, but always looking.  :devil:
