Author Topic: Antivirus Software  (Read 45427 times)
Offline in3worlds
Re:Antivirus Software
« Reply #60 on: August 06, 2004, 21:00 »
Hi Sandra,
Thanks for the welcome and the symantec link.  I ran the virus scan.  All clean.  I'll try to install NAV again later today and see what happens.
Martin
« Reply #61 on: August 07, 2004, 10:17 »
No problems with AVG here Dave, but I did follow the instructions in the link Hook mentioned.
http://pc-pals.com/index.php?board=31;action=display;threadid=10544;start=0
« Reply #62 on: August 07, 2004, 15:02 »
Thanks Adept and Hookstar.  I'll try the instructions in the link, as I can't allow it to carry on like this. It's driving me nuts.   >:(
Offline in3worlds
« Reply #63 on: August 08, 2004, 09:04 »
OK, I ran the symantec system scan for viruses and it came up clean.  I then tried to install NAV '04 and it gave me an installation error message partway through.  Any other suggestions?  Martin
Online Simon
« Reply #64 on: August 08, 2004, 09:58 »
Hi Martin,
Assuming you haven't any other Symantec products installed, try removing the Symantec folder from C:\Program Files, before trying to install NAV.  Not being funny, but is it a genuine copy you are trying to install?  I believe NAV 2004 has some sort of 'activation' procedure, similar to Windows XP, but I would have thought the error message would have been more specific, if that was the problem.
« Reply #65 on: August 09, 2004, 16:16 »
Hi Martin and  :welcome:
If you previously had NAV installed as an older version you have to be sure you have deleted all the old files from your system before installing newer version. :)
I've had similar problems but eventually got new version installed. :D
Online Simon
« Reply #66 on: August 09, 2004, 18:59 »
Here is a Symantec article on removing troublesome previous installations.  I haven't read it all, but hopefully it might help.  There is a reference to NAV 2004 at the bottom.
« Reply #67 on: January 03, 2005, 20:58 »
Found this free anti-virus:
http://www.free-av.com/
Not sure if you want to add it to your lists.
DJ1UK
I use it and it seems to work better than AVG
« Reply #68 on: January 03, 2005, 22:13 »
Thanks Davy and  :welcome:  Love your sig by the way.
« Reply #69 on: January 03, 2005, 23:17 »
Your very welcome and thank you
« Reply #70 on: January 04, 2005, 22:44 »
I have etrust antivirus pre-installed on this new pc but it's only a 60 day trial version.
Does anybody have any opinions on this software as I was thinking of getting it when my 60 day trial is up. :)
Online Simon
« Reply #71 on: January 04, 2005, 23:04 »
I asked about that myself a while ago, Lona.  I'll try to find the thread for you.  I think they are a clone of Zone Alarm, if I remember correctly, or it may be something else....  :-\
Online Simon
« Reply #72 on: January 04, 2005, 23:09 »
Found it, Lona.   and scroll down to Reply #10.   :)
« Reply #73 on: January 28, 2005, 18:03 »
Just noticed this thread Simon and yes I have uninstalled etrust and installed norton.  :) Thanks. :D
Offline Medicate
Antivirus Software
« Reply #74 on: March 19, 2005, 23:52 »
Am happy with NOD32 from eset. AV software.
Price varies with length of licence bought...........downloadable from eset website.
f in doubt, hit it with a hammer, if it doesn't fall off it's working!
