Author Topic: Antivirus Software  (Read 45433 times)
Offline Jaminxz
Re: Antivirus Software
« Reply #75 on: February 19, 2007, 15:01 »
So my AVG free edition has expired!!!
could anybody reccomend the next best free antivirus software??
thanks
« Reply #76 on: February 19, 2007, 15:54 »
It's because you are using a version which they no longer support Jaminxz.  All you have to do is download the latest version which is AVG7.5 and normal service will be restored.  see http://www.pc-pals.com/smf/index.php?topic=20681.0
Offline NevilB
  • New Registration
« Reply #77 on: January 09, 2009, 18:44 »
Malwarebytes Anti-Malware Removes Antivirus:
http://www.download.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?hhTest=1.
Download, install, update and select Full Scan.
Remove all infections that it finds after scan.
Spybot S&D:
http://www.safer-networking.org/en/download/index.html
Download, install, update and Immunize, then click 'Check for problems' then when complete select all and then 'Fix Checked'
Perfect Optimizer -- Registry Cleaner:
http://www.Easy-Registry-Clean.info
For maximum safety, Perfect Optimizer will make a backup of the repaired entries. You will be able to restore any changes made using the software by choosing Restore registry backup.
« Reply #78 on: January 09, 2009, 20:46 »
:welcome:
I think Spybot S&D is a little outdated now, and doesn't update frequently enough for my liking.  Malwarebytes appears to be a good product, and has been recommended by several forum members.  Never used Perfect Optimizer, but I am always wary of this type of program, as some registry cleaners can do more harm than good.
Offline JK
« Reply #79 on: November 29, 2009, 00:12 »
I had been using AVG 8.5 which I would have recommended to all. Forced to change to AVG 9.Internet and PC slowed down to crawl.
AVG 9 has a major problem, I  have deleated it and now use Avast.
« Reply #80 on: November 29, 2009, 01:02 »
I've heard better things about Avast than I have about AVG. :)
Offline Baz
« Reply #81 on: November 29, 2009, 08:36 »
No I dont use Spybot now have used to SUPERantispyware for a while now and it seems good.Still use Malwarebytes too.
My wife and son have avirahere on their laptops and it seems fine too.
I have the paid for NOD32 which in my opinion is very good  :thumbs:
« Reply #82 on: November 29, 2009, 10:58 »
Both of those are good, Baz.  :)
