Author Topic: Adobe does it again  (Read 1896 times)
Adobe does it again
« on: June 07, 2010, 14:36 »
El Reg reports that:
Hackers are exploiting critical, unpatched vulnerabilities in Adobe Reader, Acrobat and Flash Player.
The zero-day vulnerabilities are platform independent and can affect users of Adobe products regardless of whether they run Windows, Mac or Linux systems, Adobe warns.
The software developer reckons that Adobe Reader and Acrobat version 8.x are not vulnerable, but users of the newer version 9.0 of the software are at risk. Adobe has published a workaround involving the deletion of a library file connected with processing Flash content in PDF files pending the development of a more comprehensive fix.
Adobe is yet to publish a timetable of when patches will become available. Adobe Flash Player 10.0.45.2 and earlier versions are vulnerable to the bug. Users of Flash Player 10.1 Release Candidate may be in the clear but that's uncertain, as an advisory from Adobe explains.
The bugs are the latest in a series of security pratfalls to befall Adobe software, joint favourite with Microsoft's browser and applications as the main targets of hacker attacks. The latest flaw can be blamed on the support of exotic files and formats within PDF files, a problem that has cropped up in the past.
Re: Adobe does it again
« Reply #1 on: June 07, 2010, 15:15 »
Adobe is becoming a pariah.   >:(
« Reply #2 on: June 07, 2010, 15:18 »
Pariah Heep? ;)
« Reply #3 on: June 07, 2010, 15:21 »
Wasn't that a 70's band?   ;D
« Reply #4 on: June 07, 2010, 15:27 »
Close, though I don't think they were in their 70s at the time. ;D
« Reply #5 on: June 07, 2010, 17:40 »
They weren't my cup of tea to be honest, but I'll bet Simon was a fan!   8-)
« Reply #6 on: June 07, 2010, 18:06 »
They're probably in their 70s now!  I wasn't particularly a fan, but I know some of their stuff.  The guitarist was called Mick Box.  :)
« Reply #7 on: June 07, 2010, 18:08 »
Was he related to Cricket?
« Reply #8 on: June 07, 2010, 18:19 »
No, pillar.
« Reply #9 on: June 07, 2010, 18:40 »
Or was that Pillock? ;D
« Reply #10 on: June 07, 2010, 19:50 »
