Author Topic: Dell Sprint  (Read 3268 times)
Dell Sprint
« on: June 09, 2010, 12:48 »
Can't do links, but anyone got any opinions on the Dell Sprint?  I know it's Andriod, but looks quite configurable, and less Googleised than some Android phones I've seen.
« Last Edit: June 09, 2010, 12:50 by Simon »
Re: Dell Sprint
« Reply #1 on: June 09, 2010, 12:50 »
I've not tried it, but I think you should really bite the bullet and go for an iPhone, there may be a few floating around with the release of v4.
Re: Dell Sprint
« Reply #2 on: June 09, 2010, 13:31 »
But that would mean getting an old one.  :bawl: ;D
Re: Dell Sprint
« Reply #3 on: June 09, 2010, 13:39 »
Well, a slightly used one anyway. :)
Re: Dell Sprint
« Reply #4 on: June 09, 2010, 14:59 »
what do you mean by less Googlelised...?
I've not seen this one but if its made by Dell I'd run and run fast.
Re: Dell Sprint
« Reply #5 on: June 09, 2010, 15:02 »
Not a fan, Sam?
Re: Dell Sprint
« Reply #6 on: June 09, 2010, 15:10 »
of Dell's - no not at all.
Re: Dell Sprint
« Reply #7 on: June 09, 2010, 15:14 »
Quality issues, service, design or what?
Re: Dell Sprint
« Reply #8 on: June 09, 2010, 17:55 »
Less Googlised means having functions such as Calendar and Tasks which don't require a Google account, Sam.  It's a bit like saying users can only access the forum using Chrome.  I don't mind the Google presence, but I want the option not to use it.
The Dell is blackballed.  ;)
Re: Dell Sprint
« Reply #9 on: June 09, 2010, 18:40 »
Does that mean you're snookered? ;D :scoot:
Re: Dell Sprint
« Reply #10 on: June 09, 2010, 18:48 »
That was right on cue.
Re: Dell Sprint
« Reply #11 on: June 09, 2010, 18:50 »
I was trying to cushion the impact on your pocket.  ;D
Re: Dell Sprint
« Reply #12 on: June 09, 2010, 22:16 »
Well, it went in off.  ;)
Re: Dell Sprint
« Reply #13 on: June 10, 2010, 01:02 »
You will need to have a google account to use the software market place anyway. I just don't see the issue personally... you are either giving your details to one provider or another be it google, apple or RIM... I dunno. T'other one (who has one of these phones) thinks you might not need one to use the calendar though, but she does.
Re: Dell Sprint
« Reply #14 on: June 10, 2010, 01:12 »
There are probably other calendar apps you can download.  t think I'll stick to the BlackBerry for now.  Just got the urge for a new toy.
