November 27, 2024, 22:48
Technical Help & Discussion
Broadband, Networking, PC Security, Internet & ISPs
Cannot find IP address
Topic: Cannot find IP address (Read 3237 times)
June 12, 2010, 09:46 »
My Plusnet connection has stopped working on my PC and comes back with the errrort message "cannot find IP address". There is nothing wrong with the router because the iPad is connecting without any problelm. Any idea what might be wrong?
Re: Cannot find IP address
June 12, 2010, 11:46 »
Have you tried rebooting the PC?
June 12, 2010, 14:21 »
firewall software at fault?
You could go to the command prompt and type ipconfig, that will tell you if you are connected to the router.
actually ipconfig /all
June 12, 2010, 16:47 »
Thanks Sam. I'll try that on my next visit.
June 13, 2010, 10:45 »
Assuming you're connecting wirelessly, Clive, the first thing to check would be using a cable to eliminate the wireless side.
June 13, 2010, 11:42 »
I did that Rik and it remained the same. The iPad is wireless so I think the router is exonerated. I will be taking a look at it this afternoon.
June 13, 2010, 11:44 »
Then use ipconfig /all and paste the results, Clive.
June 13, 2010, 17:05 »
Visitors all afternoon so failed to visit the apartment. It will be tomorrow now.
Reply #9 on:
June 13, 2010, 17:06 »
OK.
Reply #10 on:
June 13, 2010, 18:52 »
as Rik said just put the results here.... and your bank details :-)
Reply #11 on:
June 13, 2010, 18:53 »
Reply #12 on:
June 13, 2010, 19:33 »
Yup, there was no connection at all and ipconfig / all would not stay on screen long enough for me to read. But I carried out a system restore and that has sorted it out. Perhaps it was a bad security update.
Reply #13 on:
June 13, 2010, 19:54 »
Odd. Ipconfig should stay there till you close the window, Clive.
Reply #14 on:
June 13, 2010, 20:09 »
Ermm... actually, this is how to do it:-
To open a console window from the command prompt:
- Type: cmd
- Type: ipconfig /all
- Then post your bank details here.
Hope this
works
helps.
Last Edit: June 13, 2010, 20:17 by Rodders
