Author Topic: Hard disc full?  (Read 2402 times)
Offline TOFFEEMAN1878
Hard disc full?
« on: June 29, 2010, 11:58 »
Hi guys&girls ,Turned on pc this morning to update it,& get a message from Spotify that my HD might be full,checked properties & it is indeed full,the disc is partitioned can I transfer files to the other partition? I am using my laptop at the moment which also is nearly full & partitioned
Hope that makes sense?      Thanks in Advance ........Jim
p.s.Or to put it another way which files& folders can I transfer to another partition from the main drive ?
« Last Edit: June 29, 2010, 12:09 by TOFFEEMAN1878 »
Re: Hard disc full?
« Reply #1 on: June 29, 2010, 12:52 »
I think you can create folders on any partition and move files / folders into it, Jim.  Is there anything currently on the freer partition?
Re: Hard disc full?
« Reply #2 on: June 29, 2010, 13:08 »
Hi Simon, I have 110GB free on the other partition.
Re: Hard disc full?
« Reply #3 on: June 29, 2010, 13:33 »
Does it show with a drive letter in My Computer, Jim?  If so, you should be able to create folders and copy / drag items to it.
Re: Hard disc full?
« Reply #4 on: June 29, 2010, 13:38 »
Yes it as C Drive  the main one is D  ,which folders etc can I copy ? is it everything accept the actual programmes?
Re: Hard disc full?
« Reply #5 on: June 29, 2010, 13:57 »
That sounds a bit odd, as usually C drive is the main drive, but you should be able to safely transfer any music, picture, and video files, which should free up some space.
Re: Hard disc full?
« Reply #6 on: June 29, 2010, 13:58 »
Try one or two first, just in case, though!
Re: Hard disc full?
« Reply #7 on: June 29, 2010, 14:22 »
Thanks Simon, Will test it on my laptop first!............Jim
Re: Hard disc full?
« Reply #8 on: June 29, 2010, 14:27 »
if you are copying audio files over and you use some program like windows media player, you'll probably have to re-index their locations.
But everything except program related files should be fine. Do you have system restore on, wonder how much that is taking up?
I know this might sound obvious, but how's the recycle bin? I've noticed people have huge ones before.... so thought its worth a mention.
Re: Hard disc full?
« Reply #9 on: June 29, 2010, 16:29 »
Running the indispensable free tool CCleaner regularly, will also help clear some space as well as emptying the bin.  The same company, Piriform, also gives away Defraggler, which may speed things up once you've made a bit of room on your system drive.
