Author Topic: Install Linux Without Burning An ISO To CD/DVD  (Read 1077 times)
« on: July 06, 2010, 00:12 »
I am assuming that Linux is not installed on your system and neither grub or lilo is there. This method is using an OpenSuse 10.2 Image but is same for Fedora or Debian or any other distro. There is one check point in case you used Nero to copy CD or DVD image then it might have been possible that you copied the image and it is file with dot nrg extension in that case you need to get the ISO from NRG.
http://www.howtoforge.com/install-linux-without-burning-an-iso-to-cd-dvd-use-the-iso-downloaded-to-your-hard-drive
