Author Topic: A clever virus  (Read 4592 times)
Offline Aaron
A clever virus
« on: July 23, 2010, 18:28 »
Hello all,
I require your help. I assume I have a virus but it eluding all of my attempts to remove it. The symptoms are as follow:
1. Services such as 'windows audio', 'DHCP client' and 'wireless zero config' fail to start despite being on 'automatic'.  They will however start manually.
2. Google on IE, firefox and opera all redirect to random sites; some well-known others malicious.
3. Windows appearance settings, although set to standard, sometimes display properly but sometimes do not. If you go in and re-apply the settings they work fine. Not sure if this one is related to point 1.
My initial thought was the google redirect virus but the online removal guides do not help as the (and I forget the name specifically) TD*.sys doesn't exist in my device manager even with the hidden items shown.
I have scanned the system with NAV, AVG, Spyhunter, Avast and Super Antispyware.  Although they all found bits and pieces none of them cured the problem.
Your help is appreciated.
Aaron
Offline Aaron
Re: A clever virus
« Reply #1 on: July 23, 2010, 18:30 »
I forgot:
System restore is turned off and I have run the AV software in safemode.
Re: A clever virus
« Reply #2 on: July 23, 2010, 18:37 »
Try Malwarebytes. Which version of Windows are you running?
Offline Aaron
Re: A clever virus
« Reply #3 on: July 23, 2010, 18:50 »
I have XP SP2. THe Malwarebytes quick-scan found nothing. The full scan is underway.
Re: A clever virus
« Reply #4 on: July 23, 2010, 19:34 »
Might be worth running HijackThis as well.
Offline Aaron
Re: A clever virus
« Reply #5 on: July 23, 2010, 20:39 »
Hi both,
Malwarebytes has completed its full scan without finding anything.
Hijack this has produced a report but I am having difficultly uploading it.
Offline Aaron
Re: A clever virus
« Reply #6 on: July 23, 2010, 20:42 »
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 20:32:57, on 23/07/2010
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v8.00 (8.00.6001.18702)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\PROGRA~1\ENIGMA~1\SPYHUN~1\SH4SER~1.EXE
C:\WINDOWS\system32\nvsvc32.exe
C:\WINDOWS\system32\svchost.exe
C:\Program Files\AVG\AVG9\avgchsvx.exe
C:\Program Files\AVG\AVG9\avgrsx.exe
C:\Program Files\AVG\AVG9\avgcsrvx.exe
C:\WINDOWS\System32\svchost.exe
C:\Program Files\Alwil Software\Avast5\AvastSvc.exe
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Common Files\Seagate\Schedule2\schedul2.exe
C:\Program Files\Symantec\LiveUpdate\AluSchedulerSvc.exe
C:\Program Files\AVG\AVG9\avgwdsvc.exe
C:\Program Files\Seagate\SeagateManager\Sync\FreeAgentService.exe
C:\Program Files\Java\jre6\bin\jqs.exe
C:\PROGRA~1\AVG\AVG9\avgtray.exe
C:\Program Files\Common Files\LightScribe\LSSrvc.exe
C:\PROGRA~1\ALWILS~1\Avast5\avastUI.exe
C:\Program Files\Common Files\Real\Update_OB\realsched.exe
C:\Program Files\Norton SystemWorks\Norton Utilities\NPROTECT.EXE
C:\Program Files\Enigma Software Group\SpyHunter\SpyHunter4.exe
C:\Program Files\Windows Live\Messenger\msnmsgr.exe
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Microsoft ActiveSync\wcescomm.exe
C:\WINDOWS\system32\PSIService.exe
C:\Program Files\AVG\AVG9\avgnsx.exe
C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
C:\PROGRA~1\MICROS~4\rapimgr.exe
C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindServiceAE.exe
C:\Program Files\TuneUp Utilities 2010\TuneUpUtilitiesService32.exe
C:\Program Files\AVG\AVG9\avgemc.exe
C:\Program Files\MagicDisc\MagicDisc.exe
C:\Program Files\Mozilla Firefox\firefox.exe
C:\Program Files\TuneUp Utilities 2010\TuneUpUtilitiesApp32.exe
C:\WINDOWS\system32\WISPTIS.EXE
C:\Program Files\Mozilla Firefox\plugin-container.exe
C:\Program Files\Windows Media Player\wmplayer.exe
C:\Program Files\Microsoft ActiveSync\WCESMgr.exe
C:\WINDOWS\system32\msiexec.exe
C:\Program Files\Trend Micro\HiJackThis\HiJackThis.exe
Offline Aaron
Re: A clever virus
« Reply #7 on: July 23, 2010, 20:42 »
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://mwe.cf.ac.uk/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R3 - URLSearchHook: AVG Security Toolbar BHO - {A3BC75A2-1F87-4686-AA43-5347D756017C} - C:\Program Files\AVG\AVG9\Toolbar\IEToolbar.dll
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0\Acrobat\ActiveX\AcroIEHelper.dll
O2 - BHO: DWABrowserHlprObj Class - {2709D830-B643-4e72-9A1E-701CFFFCF30C} - C:\WINDOWS\system32\dwabho.dll
O2 - BHO: WormRadar.com IESiteBlocker.NavFilter - {3CA2F312-6F6E-4B53-A66E-4E65E497C8C0} - C:\Program Files\AVG\AVG9\avgssie.dll
O2 - BHO: AVG Security Toolbar BHO - {A3BC75A2-1F87-4686-AA43-5347D756017C} - C:\Program Files\AVG\AVG9\Toolbar\IEToolbar.dll
O2 - BHO: AcroIEToolbarHelper Class - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Adobe\Acrobat 6.0\Acrobat\AcroIEFavClient.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll
O2 - BHO: JQSIEStartDetectorImpl - {E7E6F031-17CE-4C07-BC86-EABFE594F69C} - C:\Program Files\Java\jre6\lib\deploy\jqs\ie\jqs_plugin.dll
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Acrobat 6.0\Acrobat\AcroIEFavClient.dll
O3 - Toolbar: AVG Security Toolbar - {CCC7A320-B3CA-4199-B1A6-9F516DD69829} - C:\Program Files\AVG\AVG9\Toolbar\IEToolbar.dll
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [AVG9_TRAY] C:\PROGRA~1\AVG\AVG9\avgtray.exe
O4 - HKLM\..\Run: [avast5] C:\PROGRA~1\ALWILS~1\Avast5\avastUI.exe /nogui
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files\Common Files\Real\Update_OB\realsched.exe"  -osboot
O4 - HKLM\..\Run: [SpyHunter Security Suite] "C:\Program Files\Enigma Software Group\SpyHunter\SpyHunter4.exe" -minimize
O4 - HKLM\..\Run: [Malwarebytes Anti-Malware (reboot)] "C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe" /runcleanupscript
O4 - HKLM\..\RunOnce: [Malwarebytes' Anti-Malware] C:\Program Files\Malwarebytes' Anti-Malware\mbamgui.exe /install /silent
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\Windows Live\Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
Offline Aaron
Re: A clever virus
« Reply #8 on: July 23, 2010, 20:43 »
O4 - HKCU\..\Run: [H/PC Connection Agent] "C:\Program Files\Microsoft ActiveSync\wcescomm.exe"
O4 - HKCU\..\Run: [SUPERAntiSpyware] C:\Program Files\SUPERAntiSpyware\SUPERAntiSpyware.exe
O4 - HKUS\S-1-5-19\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-18\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\CTFMON.EXE (User 'Default user')
O4 - Startup: MagicDisc.lnk = C:\Program Files\MagicDisc\MagicDisc.exe
O6 - HKCU\Software\Policies\Microsoft\Internet Explorer\Control Panel present
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\Office12\EXCEL.EXE/3000
O9 - Extra button: Send to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra 'Tools' menuitem: S&end to OneNote - {2670000A-7350-4f3c-8081-5663EE0C6C49} - C:\PROGRA~1\MICROS~2\Office12\ONBttnIE.dll
O9 - Extra button: Create Mobile Favorite - {2EAF5BB1-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MICROS~4\INetRepl.dll
O9 - Extra button: (no name) - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MICROS~4\INetRepl.dll
O9 - Extra 'Tools' menuitem: Create Mobile Favorite... - {2EAF5BB2-070F-11D3-9307-00C04FAE2D4F} - C:\PROGRA~1\MICROS~4\INetRepl.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\Office12\REFIEBAR.DLL
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
Offline Aaron
Re: A clever virus
« Reply #9 on: July 23, 2010, 20:45 »
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
Offline Aaron
Re: A clever virus
« Reply #10 on: July 23, 2010, 20:46 »
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
Offline Aaron
Re: A clever virus
« Reply #11 on: July 23, 2010, 20:47 »
O16 - DPF: {644E432F-49D3-41A1-8DD5-E099162EEEC5} (Symantec RuFSI Utility Class) - http://security.symantec.com/sscv6/SharedContent/common/bin/cabsa.cab
O16 - DPF: {6CE31B8D-8340-4DBD-B78E-BF59620924DC} (Quest3DCtlr2 Class) - http://www.quest3d.com/webplugin/download/quest3dactivex2.cab
O16 - DPF: {983A9C21-8207-4B58-BBB8-0EBC3D7C5505} (Domino Web Access 8 Control) - https://cardiffmail15.cf.ac.uk/dwa8W.cab
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://fpdownload2.macromedia.com/get/shockwave/cabs/flash/swflash.cab
O18 - Protocol: avgsecuritytoolbar - {F2DDE6B2-9684-4A55-86D4-E255E237B77C} - C:\Program Files\AVG\AVG9\Toolbar\IEToolbar.dll
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG9\avgpp.dll
O20 - Winlogon Notify: !SASWinLogon - C:\Program Files\SUPERAntiSpyware\SASWINLO.DLL
O20 - Winlogon Notify: avgrsstarter - avgrsstx.dll (file missing)
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\System32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\System32\browseui.dll
O23 - Service: Acronis Scheduler2 Service (AcrSch2Svc) - Acronis - C:\Program Files\Common Files\Seagate\Schedule2\schedul2.exe
O23 - Service: Adobe LM Service - Unknown owner - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Automatic LiveUpdate Scheduler - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\AluSchedulerSvc.exe
O23 - Service: avast! Antivirus - AVAST Software - C:\Program Files\Alwil Software\Avast5\AvastSvc.exe
O23 - Service: avast! Mail Scanner - AVAST Software - C:\Program Files\Alwil Software\Avast5\AvastSvc.exe
O23 - Service: avast! Web Scanner - AVAST Software - C:\Program Files\Alwil Software\Avast5\AvastSvc.exe
O23 - Service: AVG Security Toolbar Service - Unknown owner - C:\Program Files\AVG\AVG9\Toolbar\ToolbarBroker.exe
O23 - Service: AVG Free E-mail Scanner (avg9emc) - AVG Technologies CZ, s.r.o. - C:\Program Files\AVG\AVG9\avgemc.exe
O23 - Service: AVG Free WatchDog (avg9wd) - AVG Technologies CZ, s.r.o. - C:\Program Files\AVG\AVG9\avgwdsvc.exe
O23 - Service: Seagate Service (FreeAgentGoNext Service) - Seagate Technology LLC - C:\Program Files\Seagate\SeagateManager\Sync\FreeAgentService.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: Java Quick Starter (JavaQuickStarterService) - Sun Microsystems, Inc. - C:\Program Files\Java\jre6\bin\jqs.exe
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files\Common Files\LightScribe\LSSrvc.exe
O23 - Service: LiveUpdate - Symantec Corporation - C:\Program Files\Symantec\LiveUpdate\LuComServer_3_4.EXE
O23 - Service: NMIndexingService - Nero AG - C:\Program Files\Common Files\Ahead\Lib\NMIndexingService.exe
O23 - Service: Norton Unerase Protection (NProtectService) - Symantec Corporation - C:\Program Files\Norton SystemWorks\Norton Utilities\NPROTECT.EXE
O23 - Service: NVIDIA Display Driver Service (nvsvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: ProtexisLicensing - Unknown owner - C:\WINDOWS\system32\PSIService.exe
O23 - Service: SpyHunter 4 Service - Enigma Software Group USA, LLC. - C:\PROGRA~1\ENIGMA~1\SPYHUN~1\SH4SER~1.EXE
O23 - Service: StarWind AE Service (StarWindServiceAE) - Rocket Division Software - C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindServiceAE.exe
O23 - Service: SymWMI Service (SymWSC) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\Security Center\SymWSC.exe
O23 - Service: TuneUp Drive Defrag Service (TuneUp.Defrag) - TuneUp Software - C:\Program Files\TuneUp Utilities 2010\TuneUpDefragService.exe
O23 - Service: TuneUp Utilities Service (TuneUp.UtilitiesSvc) - TuneUp Software - C:\Program Files\TuneUp Utilities 2010\TuneUpUtilitiesService32.exe
End of file - 11428 bytes
Offline Aaron
Re: A clever virus
« Reply #12 on: July 23, 2010, 20:51 »
Wow, that was difficult. One line of the report kept making the connection to pc-pals timeout. I assume some form of firewall was triggered.  I have put the line below and inserted @ signs randomly. Hopefully it will get through (there were not @ signs in the line to start with).
O16 - DPF: {641451@2B-B978-45@1D-A0D8-FCFDF3@3E833C} (WUWebC@ontrol Class) - http://upd@ate.microsoft.com/windows@update/v6/V5Controls/en/x86/cli@ent/wuweb_site.cab?12502604@13937
Re: A clever virus
« Reply #13 on: July 23, 2010, 21:27 »
I'm no expert on these, but I can't see anything glaringly obvious.  I do note, however, that AVG, Avast, and Norton, as well as Spyware Hunter, all appear in the results.  Do you have all of these installed and running?  It's not a good idea to have too many security, particularly anti-virus programs running at once, as they can conflict with each other.
I believe you can upload the HijackThis file to the TrendMicro site for analysis.  That might be worth a go, but if none of the spyware removers you have tried have found anything (even in safe mode?), I'm wondering if the simplest solution might be to backup your data, format, and do a fresh installation of Windows, then at least you will know that your system is clean.
Offline Aaron
Re: A clever virus
« Reply #14 on: July 23, 2010, 22:22 »
They are running in unison, yes.
Unfortunately I have reached the same conclusion with regards a fresh install. It's just the potch of it all that has made me persevere for the last couple of months.  I will upload the file to the forum and see what comes out, but like you, I can see nothing obviously wrong.
