Author Topic: A clever virus  (Read 4589 times)
Re: A clever virus
« Reply #15 on: July 23, 2010, 22:34 »
I'd have probably done the same with regards to delaying the fresh install, as it is a pain, but you could spend another couple of months trying to get it fixed.  Once you've done it, though, I'd recommend getting one decent security suite, such as F-Secure or ESET (I use F-Secure), and not having several on the go at once, especially anti-virus.  You can usually get away with a couple of anti-spyware apps running together, but keep any others reserved for on-demand scans, not running in real time.
Re: A clever virus
« Reply #16 on: July 24, 2010, 10:29 »
Might be a good idea to move to SP3 at the same time.
