Author Topic: AIDA32 update  (Read 1121 times)
AIDA32 update
« on: April 29, 2003, 18:56 »
If you're using AIDA32 you can check for version updates by opening the AIDA32 program and clicking on File> NetUpdate
the latest release is version 3.40 and the AIDA program will check it for you.
Hookstar
Re:AIDA32 update
« Reply #1 on: April 29, 2003, 18:59 »
Thanks Hook.  I find that bit of software very useful and have used it several times.
Re:AIDA32 update
« Reply #2 on: May 01, 2003, 15:59 »
You can go off people you know,Sandra is far better than Aida  ::)
Re:AIDA32 update
« Reply #3 on: May 01, 2003, 18:07 »
No it isn't!   ;D
