Author Topic: Win Drivers backup  (Read 1449 times)
Win Drivers backup
« on: April 29, 2003, 19:04 »
Found this very interesting  :)backup windrivers
WinDriversBackup Personal Edition is a free utility for personal, non-commercial use, provided by JerMar Software Corp. specifically for backing up your Windows system driver files.
WinDriversBackup can identify all of your Windows driver files and save them to a secure location in two simple mouse clicks.
Backing up your Windows driver files means they will be available to you the next time you need to reinstall the driver or the whole operating system. WinDriversBackup places the driver files in one organized location of your choosing.
WinDriversBackup is especially helpful in situations where you have a computer in your possession and it's internal hardware is unknown. WinDriversBackup can identify the hardware on the system and the associated drivers ---then back them up to a specified location. WinDriversBackup is even network compatible --you can just as easily connect to a remote computer on your network and backup driver files.
Hookstar
Offline bat69
Re:Win Drivers backup
« Reply #1 on: April 29, 2003, 20:23 »
Thanks Hook ... that seems to do automatically what I do manually ... and yes I'm gonna get lazier  ;D  too much effort at the gym  :P
« Reply #2 on: April 29, 2003, 21:03 »
too much letching at the gym no doubt ;) :P
Offline bat69
« Reply #3 on: April 29, 2003, 23:39 »
WELLLLLLLLLLLLL  :P :P :P ;D ;D ;D
What can I say  ;) ;)
