Author Topic: Won't boot  (Read 3632 times)
Offline jww41005
Won't boot
« on: September 06, 2010, 16:44 »
Hi pals,
This morning my tabletop decided not to boot up.
File:\windows\system32\winload.exe
Status: 0xc000000e
Missing or corrupt.
Does anyone know a quick fix for this?
Cheers
John
If it works, don't fix it
Re: Won't boot
« Reply #1 on: September 06, 2010, 16:56 »
can you get into safe mode?
do you have the windows cd - run the recovery console.
Re: Won't boot
« Reply #2 on: September 06, 2010, 17:16 »
Can you get the boot menu up and try Last good configuration?
Offline jww41005
Re: Won't boot
« Reply #3 on: September 07, 2010, 16:05 »
Thanks guys,
At first there was no reaction when I put the CD in, so I left it for a day. A few hours ago I put the Cd in and it worked.?? Must be a female PC.
Cheers!
John
Re: Won't boot
« Reply #4 on: September 07, 2010, 16:08 »
Re: Won't boot
« Reply #5 on: September 07, 2010, 18:41 »
Thanks for letting us know.  :)
