Author Topic: IE problems  (Read 1833 times)
Offline Andy K
IE problems
« on: September 18, 2010, 22:12 »
I run Windows XP and IE7 which I am very happy with.
However I have a problem (in the last few days) where by on a couple of internet pages, the page loads, I get an error message saying it can't be loaded and then the page blanks. (for example facebook)
I have run ccleaner.
Have have tried manually restoring (with good copies) the Windows, Program Files, and Docs&Settings and system files in root, but that hasn't helped.
Have also tried system restore.
What else can I do before I put a fresh copy of windows on? (don't really want to as apart from this is it running great)
Thanks for any tips
Re: IE problems
« Reply #1 on: September 19, 2010, 00:01 »
Hi Andy,
Do these web pages fail to load all of the time?  Other web pages are OK, yes?  Have you tried a different browser, such as Firefox?  Also, in IE, have you cleared the cache / temp internet files and cookies?  That sometimes helps.
Offline Andy K
Re: IE problems
« Reply #2 on: September 19, 2010, 12:01 »
yes it happens all the time.
i have tried clearing cookies and temp files but didn't help this time.
website works on another pc ok
Re: IE problems
« Reply #3 on: September 19, 2010, 12:09 »
So, have you tried another browser, such as Firefox?
Offline Andy K
Re: IE problems
« Reply #4 on: September 19, 2010, 12:22 »
no. Cus i want to use IE.
I guess i could try IE8 in the hope it accidently fixes it.
Re: IE problems
« Reply #5 on: September 19, 2010, 15:11 »
Fair enough.
Offline Andy K
Re: IE problems
« Reply #6 on: September 19, 2010, 15:24 »
silly thing would let me put ie8 on.
Wants to put an update on first, but then says the update is already there in a service pack.
Re: IE problems
« Reply #7 on: September 19, 2010, 15:42 »
Did it say which update it wanted?
