Author Topic: Annoying Outlook Express  (Read 3315 times)
Offline Big_Boss
« on: May 01, 2003, 16:26 »
Hi,
Ive got a small problem with Outlook Express and Windows Messenger. Every time i start Outlook Express 6, without, fail, windows messenger starts also, ive had a look in the options and there is a ticky box to disable it. I tried unticking it, but it still pops up  ???
Im sure there is a proggie out there to stop this, there usually is for most annoying things  ;D
Thanks in advance,
Boss
Re:Annoying Outlook Express
« Reply #1 on: May 01, 2003, 16:46 »
If you are on XP (as I think you must be BB as you have windows messenger not msn one),I think its tied in with it.
I had the same thing and also found that it cluttered my address book on OE as well with all my hotmail contacts addresses and whether they were on line or not.
I eventually removed windows messenger  4.7 and installed msn messenger ver 5 and all is fine once again  :-*
Offline Big_Boss
« Reply #2 on: May 01, 2003, 16:52 »
Yeah i'd have no problem uninstalling messenger 4.7 but sometimes i use a program called GameVoice for in-game chat, and it wont work with MSN 5, not sure why.
I know there is definitely a tool to disable it out there. I remember someone writing into Computeractive about it. Cant remember what the answer was though and i cant find anything on google.  :-[
Boss
« Reply #3 on: May 01, 2003, 16:56 »
Oh well if youre stuck with it BB someones going to have to find the answer,hopefully with all of us looking one of us should come across it fairly quickly if no one knows how already  :-*
« Reply #4 on: May 01, 2003, 17:02 »
Have a look at the link below:
http://support.microsoft.com/?kbid=327390
Hope it helps.
« Reply #5 on: May 01, 2003, 17:10 »
That looks like it should do it Dave,chalk another one up to Lancashire  ;)
Offline Big_Boss
« Reply #6 on: May 01, 2003, 17:41 »
Hope it helps.
As i said before, i unticked the box in options as it states on that page:
RESOLUTION
To prevent Windows Messenger from signing on when you start Outlook Express:
In Outlook Express, click Options on the Tools menu.
On the General tab, click to clear the Automatically log on to Windows Messenger check box.
Click OK.
This however doesnt seem to work  :(
Ill try re-enabling it and disabling it, see if that helps.
Boss
EDIT: I also havent removed access to it as it says, as i need the program.
« Reply #7 on: May 01, 2003, 17:48 »
I think its meaning remove access for the other progs to start it BB.Then its stil available from start menu as when you want to use it  ;)
« Reply #8 on: May 01, 2003, 17:58 »
If you open Windows Messenger, go to Tools > Options > Preferences, then untick the box that says 'Start with Windows' (or similar), that might help.  Then open Outlook Express, and go to Tools > Options, and in the General tab, untick the box that says 'Automatically start Windows Messenger'.  That should do it, BB.   :)
Offline Big_Boss
« Reply #9 on: May 01, 2003, 19:09 »
Afraid not Simon  :-[ I opened winows messenger and went into options, that box is already unticked. The one is OE is also.
This has got me stumped  ::) or windows could be up to its old tricks again...
« Reply #10 on: May 01, 2003, 19:16 »
Don't know if this tip will be helpful Big_Boss
http://www.tweakxp.com/tweakxp/display.asp?id=979
Offline Big_Boss
« Reply #11 on: May 01, 2003, 19:21 »
Fixed it!!  ;D ;D ;D
Found this site, via a second searching of google
Created the new registry value and voila, no more windows messenger  :D
Thanks for all the advice though  :)
Boss
« Reply #12 on: May 01, 2003, 21:00 »
That's a useful looking site BB.  I've added it to my Bookmarks as it might come in useful at times.
Glad you sorted your problem.  :)
Cheers.
Offline ketamininja
« Reply #13 on: May 09, 2003, 10:41 »
Now here is something interesting...
Of course the same "problem" occurred with myself - WINDOWS messenger comes up, even tho I use MSN Messenger.
Now, I hadn't really looked at this, but here we go:
On one of my home machines, Wmessenger STOPPED appearing. Mmessenger stays as it should. Well, I didn't bother about this.
After reading this thread, and KNOWING that my work PC is the same as this thread - I thought I would do some registry hacking. Well, lets start OE first.
Erm - it didn't load Wmessenger this time!!
So: If you close Wmessenger so many times when OE is running (and you may have to have Mmessenger running too), then it just stops appearing, as if it knows LOL  :D
Don't think its my magic touch - but computers do FLAKE when I go near them (uh - oh)...
« Reply #14 on: May 09, 2003, 14:08 »
Actually, I think XP does have some sort of 'learning' capability.  If you perform the same tasks in the same way enough times, it eventually gets the message and does it automatically for you.   :)
