Author Topic: SSD  (Read 11896 times)
SSD
« on: October 06, 2010, 18:56 »
Just installed one of These little beauties  :o: with a 1TB as storage space  :o
Re: SSD
« Reply #1 on: October 06, 2010, 19:51 »
Nice one Terry!   8-)
Re: SSD
« Reply #2 on: October 06, 2010, 20:02 »
All I can say is WOW..what a difference the speed is now on the hard drive  :thumbs: :o:
Re: SSD
« Reply #3 on: October 06, 2010, 20:41 »
Hard drive speed is probably something you don't really notice, until you vastly improve it.  :thumb:  I'm a bit confused, though.  That one seems to be a 60Gb drive, so have you got two of them, the other being 1Tb, Terry?
Re: SSD
« Reply #4 on: October 06, 2010, 22:33 »
Correct Si,   Operating system on the 60GB and storage etc on the 1Tb
Re: SSD
« Reply #5 on: October 06, 2010, 23:21 »
Cool!  :thumbs:
Re: SSD
« Reply #6 on: October 07, 2010, 04:58 »
solid state is phenomenally fast.. still I'm limited by the speed that the computer can pipe the data... when you hit that, you are screwed no matter what.
Re: SSD
« Reply #7 on: October 07, 2010, 07:18 »
Re: SSD
« Reply #8 on: October 07, 2010, 10:45 »
 :o very impressive. I really fancy ditching mechanical drives myself, my only reservation being i've read that the number of read / write functions the drives can do are limited and the drive will slow down and eventually die. What is the projected life of these SSD drives ?
Re: SSD
« Reply #9 on: October 07, 2010, 14:14 »
also remember there is no way of getting data back if the hard drive gets messed up, its not written on surface anymore.
Re: SSD
« Reply #10 on: October 07, 2010, 14:15 »
bit of discussion on read/writes on the eeeuser wiki: http://wiki.eeeuser.com/ssd_write_limit
Re: SSD
« Reply #11 on: October 07, 2010, 15:16 »
The only data that is contained on the new SSD is the operating system as the rest is stored on the 1TB storage HD  :leer:
Re: SSD
« Reply #12 on: October 08, 2010, 04:36 »
perfect, so you get all the speed advantages of the SSD without quiet the worry...but the answer is simple, multiple backups.. offsite backups... maybe I'm just paranoid.
Re: SSD
« Reply #13 on: October 08, 2010, 10:14 »
Ask Rik...  ;)
Re: SSD
« Reply #14 on: October 08, 2010, 12:02 »
Loaded win 7 home premium in under 10 mins  :o:
