Author Topic: Anyone Used This Optimiser?  (Read 1920 times)
« on: November 03, 2010, 21:52 »
For a while now, I have been using a handy little defragmenter from a company called Iobit - Smart Defrag
The company also produces a system optimisation program Advanced System care.
Has anyone used it?
Thanks.
Re: Anyone Used This Optimiser?
« Reply #1 on: November 03, 2010, 22:18 »
Not heard of it before Dave but I will certainly give the defrag a go!   8-)
« Reply #2 on: November 03, 2010, 23:36 »
I don't use any of those tools, so can't help, sorry Dave.
« Reply #3 on: November 04, 2010, 00:05 »
When I used windows I tried them
they seemed to do the job and did a good job of it
Iobit's programs all do a good job
« Reply #4 on: November 04, 2010, 00:15 »
Is Iobit and Auslogic the same company?  Screen shots of their disk defragger look identical.  If so, I can recommend the defragger from personal experience.
« Reply #5 on: November 04, 2010, 00:24 »
use linux, you'll never need to worry again  :devil:
« Reply #6 on: November 04, 2010, 00:24 »
the real question is which one can be obtained the easiest.
